A markdown outline sidebar plugin for Joplin
This plugin isn’t able to work after updating Joplin to 3.5.11. (clicking on the headers at the sidebar does not do anything)
Any others facing the same issue?
I need a good TOC/Outline plugin :frowning:
Are you using the rich text editor? the scroll to header appears to work in the markdown editor, but not the rich text editor
The DDDot plugin's outline does seem to work with the rich text editor in v3.5.11: Joplin Plugins - Joplin DDDot
Oh yes, I am using the rich text editor. Thanks for the DDDot plugin recommendation! :grin:
Same here: Outline discontinued its service with the Jopin update to version 3.5.11. I like it and miss it very much :sleepy_face:
Is there any workaround to get it working again?
For me Outline seems to work fine (1.5.15) and Joplin 3.6.2 :thinking:
Details
Joplin 3.6.2 (prod, win32)
Appareil : win32, Intel(R) Core(TM) i5-4310U CPU @ 2.00GHz
ID client : 773c93d7dee04e1289cb896f235df6a3
Version de Synchro : 3
Version du profil : 49
Trousseau supporté : Oui
ID d'instance alternatif : -
Révision : c5d9646
Backup: 1.5.1
Bidirectional Links: 0.2.1
Combine notes: 1.2.3
Favorites: 1.3.2
Freehand Drawing: 4.3.0
MultiMarkdown Table Tools: 1.2.1
Note list and sidebar toggle buttons: 1.0.3
Note overview: 1.7.1
Note Tabs: 1.4.0
Outline: 1.5.15
Persistent Editor Layout: 2.2.0
Quick Links: 1.3.2
Rich Markdown: 0.17.1
Search & Replace: 2.2.0
Hi nonobio,
…sure you’re using Joplin 3.6.2?
Last official version is still 3.5.12 (prod, win32).
Workaholic
Outline continues to work for me fine here also.
Joplin Version 3.6.2 is a pre-release, available here, but I haven't had any issues with earlier versions of Joplin with the Outline plugin. Maybe you could try disabling other plugins to determine if there is some impact from another plugin?
I've used both DDDot and Outline for a long time, kudos to both @benlau and @cqroot :glowing_star:
P.S.
Also using Outline plugin v1.5.15
Hi @Workaholic , yes I use 3.6.2 version, it is beta version as @johano says.
Maybe you can try to install it.
@ johano: Ah, okay, thanks. I only ever use the officially released versions.
It's strange that Outline runs smoothly for you but not for me :face_with_diagonal_mouth:
@ nonobio: Thanks, maybe I'll give that a try. However, I've never had any problems with other plugins (I only have one more installed).
I can re-create the issue in 3.6.2 as well (only in the rich text editor)
What appears to be happening is that it's scrolling to the cursor position and not the heading that you clicked on, steps to re-create:
  1. Switch to rich text editor
  2. Left click somewhere in document to place the cursor
  3. Scroll up to the top of the document
  4. Click a heading
  5. It will then scroll to wherever you placed the cursor in step 2 (not to the heading)
Edit: I submitted a pr with a fix for this: Fix: scroll to heading (and scroll to top) in rich text editor, Fixes #114 by bwat47 · Pull Request #115 · cqroot/joplin-outline
I use the Markdown editor exclusively, that's why I didn't see the problem :slight_smile: I didn't think to tell you about that @Workaholic , thanks @bwat47 :slight_smile:
bwat47: Thanks for analyzing and bug reporting :+1:
nonobio: No problem. I almost exclusively use the rich text editor.
@Workaholic,
Ditto, here I'm also using only the markdown editor, sorry for any confusion. I'll make a mental note to mention that relevant fact in future posts! :slightly_smiling_face: :waving_hand:
I have the same problem with Joplin 3.5.12 (prod, linux)
I would be very glad to get a fix because I like to use the rich text editor.
Thank you !!!
Appareil : linux, Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
ID client : afaf8c86b5fb414f88fa12aa0b0ecc7b
Trousseau supporté : Non
Révision : 449555c
Backup: 1.5.1
Insert Date: 1.0.1
LanguageTool integration: 0.1.0
Outline: 1.5.15
Quick Links: 1.3.2
Resource Search Plugin: 0.1.2
