"yo joplin" for pre-releases?
I test 1.4.11 now and it has different api/types.ts than 1.3.8.
Is there a way to get newest api for plugin via yo generator?
Ok got it, i had to reinstall generator-joplin sudo npm install -g generator-joplin
Glad you solved it here! Just for your reference you can also use yo to update the plugin API.
