YesYouKan not showing and devtools window coming up at startup
macOS
Joplin 3.3.12 (prod, darwin)
Appareil : darwin, Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
ID client : 72155f33336b471a93ad7a4bd245ec92
Version de Synchro : 3
Version du profil : 47
Trousseau supporté : Oui
ID d'instance alternatif : -
Révision : 4d790b6
Backup: 1.4.3
Enhancement: 1.2.1
footnotes: 1.0.0
Freehand Drawing: 3.0.1
Katex Input Helper: 2.0.1
YesYouKan: 1.0.17
I have two problems and one question.
First, since I've updated Joplin, I have that annoying html/css devtools window that keeps coming up at every startup. How can I delete it ? I'm using a dev plugin for footnotes, and it might be related...
Second, I want to use the YesYouKan plugin but I can't access the Board vue even after trying to do all what is said on both joplin and github plugin page. In fact, I can't see the 'eye' button in the top right corner. How can I toggle the vue to see the board ?
Finally, I'm using a translated version so how can I help to translate the few buttons left ?
Thanks
