Joplin 3.4.12 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: 0eba133bf40e422fa62146c80df1b9b3
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
AlertsPerfect: 1.0.1
Backup: 1.4.3
CodePerfect: 1.0.2
Csv Import: 1.0.1
Editor Themes: 1.0.2
Extra Markdown editor settings: 1.11.0
Google Fonts Plugin: 1.0.0
Headings 4 to 6: 1.0.1
Hotstrings & Hotkeys: 1.0.1
Insert Date: 1.0.1
Math Mode: 0.8.3
Note Statistics: 1.0.4
Search & Replace: 2.2.0
Table Formatter Plugin: 1.2.1
Templates: 3.0.0
Text Colorize: 1.2.5
OneDrive
Several things appear to be happening. When I start Joplin Notes, the screen flickers and nothing appears to happen. Then when click the icon again, I get TWO copies. One copy has a new notebook I just created about an hour ago and the other does not have that notebook. I suspect these are two different issues, but I don't know how to describe it any different.
I can close the one without the new notebook and work find, but I don't know why that other version appears.
Also, spell check stopped working. I turned it off and on. I restarted (which is when I noticed the 2 versions starting up).
Sync is not throwing any errors and backup worked too. I did an export-all to a .jex file as a precaution.
