macOS
Joplin for Desktop
Copyright © 2016-2024 Laurent Cozic
Joplin 3.0.15 (prod, darwin)
Client ID:
Keychain Supported: No
Revision: 598677b
Backup: 1.4.1
Combine notes: 1.2.2
Draw.io: 2.2.0
Folding in Code Mirror Editor: 2.0.1
Joplin Batch: 0.2.2
joplin-excalidraw: 1.3.0
Kanban: 1.1.0
Omnivore Sync: 0.2.0
Search & Replace: 2.2.0
Simple Highlighter: 1.0.0
Templates: 2.4.0
Using the Folding in Code Mirror Editor v2.0.1 Joplin sometimes show the anomalies highlighted in the enclosed screen shot.
The issue disappears if i zoom out and in again (command+ and command-). After a while the issue is back. Have been like that since I started using the plugin.
