Userstyles.css error with Source family fonts
Joplin 3.6.14 (prod, win32)
Dispositivo: win32, Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
ID do cliente: 3cbbbc1d22dc47129a3f98de3fcf7684
Versão Sync: 3
Versão do Perfil: 49
Keychain Suportada: Sim
ID da instância alternativa: -
Sync target: Dropbox
Editor: Markdown
Revisão: 7e2765a
Backup: 1.5.1
Freehand Drawing: 4.3.0
Dropbox
I have a custom style sheet for the rendered markdown, it is very simple and I only change a few things, like the font family. The issue is that, recently, the app is failing to render specifically the Source Sans 3 font, which is the one I want to use.
Even more, when I put Source Sans 3 as the first option in the style sheet, with other fonts as alternatives after it in the code, the app overlooks all the other options and goes straight to the sans-serif fallback font.
I am certain that Source Sans 3 is installed in my device, and my code is as follows:
body {
font-family: Source Sans 3, Calibri, Roboto, Liberation Sans, Arial Nova, Arial, sans-serif;
font-size: 12pt;
font-variant-numeric: tabular-nums;
text-align: justify;
color: black;
When I test with other fonts, everything works fine. It is a problem specifically with Source Sans 3, for some reason.
Not sure if this is the actual culprit, but your CSS is incorrect. Font names are supposed to be quoted, i.e.
font-family: "Source Sans 3", "Calibri", "Roboto", "Liberation Sans", "Arial Nova", "Arial", sans-serif;
Thank you very much, that was the issue. I've always written without quotes for some reason, and it always worked nonetheless.
Right. You don't need quotes surrounding the one-word families. And hence, you were seeing a partial success of your list.
Technically, assuming that Mozilla's documentation is accurate, quotes in this case are always required (see https://developer.mozilla.org/en-US/docs/Web/CSS/Reference/Properties/font-family#family-name). But web browsers (and Electron, etc.) are forgiving, hence unquoted single-word names will work even if the code isn't 100% correct.
I stand corrected. Legacy stuff.
