Userchrome.css is not being applied
Joplin 3.1.20 (prod, win32)
Client ID : f63c7a89327942c58c23651917087dee
Sync Version : 3
Profile Version : 47
Keychain Supported : Yes
Revision : 8199362
Backup : 1.4.2
Font Size Shortcut: 1.0.0
Text Colorize: 1.2.5
Dropbox
Thank you for providing such a excellent application!
There's one issue.
After upgrading the application to version 3.1.20, specifying the text color for links and addresses in userchrome.css does not change anything.
The bold text color also does not change.
When reverting to 3.0.15, it will be applied.
Is this a bug?
@3gi8ma welcome to the forum.
No. The Markdown editor was changed between v3.0.x and v3.1.x and some css classes were also changed. This is not a bug as custom css is an unsupported feature. Explained a bit better here.
You can either rewrite your userchrome.css file for the new editor or revert to what is now the legacy editor.
Tools> Options > General > Advanced > Use the legacy Markdown editor
Thank you.
I got it set up.
If it works now, are your custom styles retained after opening and closing the tools, options menu?
