Joplin TRMNL Push
Plugin page: Joplin Plugins - TRMNL Push
Push Joplin search results to a TRMNL private plugin webhook.
A note such as this one:
## Today
- [ ] Morning workout
- [ ] Finish quarterly report
- [ ] Call insurance provider
- [x] Book dentist appointment
- [ ] Buy groceries
## Meals
- Lunch: Chicken salad
- Dinner: Pasta with vegetables
## Reminders
- Bin collection tomorrow
- Mum's birthday on Friday
- Electricity bill due in 3 days
would render like so in the TRMNL device:
- Configure a Joplin search query to find matching notes
- Push results to TRMNL as merge variables
- Two display modes: list of notes, or single note with body
- Manual push via Tools menu command
- Optional periodic automatic push
- Configurable result limit
- Optional updated time for each note
- Search for "TRMNL Push" from Joplin
- Install it
- Follow the instruction below for setup
TRMNL Setup
Before configuring the Joplin plugin, set up a Private Plugin on the TRMNL side:
- Log into usetrmnl.com and go to Plugins.
- Add a new Private Plugin.
- Give it a name (e.g. "Joplin Search").
- Set the Strategy to Webhook β TRMNL will generate a unique webhook URL.
- Copy that URL β you'll paste it into the Joplin plugin settings below.
- In the TRMNL plugin editor, paste the markup template (see TRMNL Template below). Merge variables become available once data has been pushed at least once.
- After completing the Joplin configuration, run Tools > Push search results to TRMNL to send the first payload β this registers the variable schema with TRMNL so the merge variables become available in the template editor.
- Add the plugin to a Playlist so it appears in your device's screen rotation.
See the TRMNL Private Plugins documentation for the canonical reference on the webhook strategy, payload shape, and Liquid templating.
Configuration
Go to Settings > TRMNL Push and configure:
| Setting | Description |
| TRMNL Webhook URL | The webhook URL from your TRMNL private plugin |
| Search Query | Joplin search query (e.g., tag:todo type:note) |
| Display Mode | List of notes (titles only) or Single note (with body) |
| Result Limit | Maximum number of notes to include in list mode (default: 5) |
| Push Interval | Automatic push interval in minutes (0 to disable) |
| Include Updated Time | Include last updated time for each note |
In Single note mode, the most recent matching note is sent with its body. Result Limit is ignored in this mode.
Go to Tools > Push search results to TRMNL to push the current search results to your TRMNL device. Run this once after setting up your config to verify everything works and to register the merge variables with TRMNL.
TRMNL Template
The plugin sends one of two payload shapes, depending on the Display Mode setting.
List mode payload:
"merge_variables": {
"title": "Joplin Search",
"query": "tag:todo type:note",
"count": 3,
"mode": "list",
"items": [
{ "title": "Review PR", "updated": "2026-03-13 09:20" },
{ "title": "Release notes", "updated": "2026-03-12 18:05" }
"pushed_at": "2026-03-13 14:00"
Single-note mode payload:
"count": 1,
"mode": "single",
"items": [ { "title": "Review PR", "updated": "2026-03-13 09:20" } ],
"note": {
"updated": "2026-03-13 09:20",
"body": "Check the auth refactor...",
"body_html": "<p>Check the <strong>auth refactor</strong>...</p>"
note.body is the raw Markdown of the note. note.body_html is the note rendered to HTML β use this in your template so bold, italics, lists, checkboxes, and headings render properly on the device.
A few things to keep in mind:
- Keep matched notes short. Long notes are clipped to fit TRMNL's payload limit, ending with
β¦. - Joplin attachment images won't display. Use external HTTPS image URLs (
) for any images you want on the device. - Raw HTML in your notes is rendered as-is. If you want fine-grained control over the layout of a specific note (custom spans, divs, inline styles), just write the HTML directly in the note.
The following template handles both display modes. Paste it into the Markup field of your Private Plugin's Full view:
<style>
.j-layout {
padding: 16px;
box-sizing: border-box;
height: 100%;
font-family: sans-serif;
font-size: 20px;
.j-title { font-size: 1.4em; font-weight: bold; }
.j-meta { font-size: 0.7em; opacity: 0.7; margin-top: 2px; }
.j-list { margin-top: 0.6em; }
.j-list-item { padding: 0.3em 0; border-bottom: 1px solid #000; }
.j-list-item-title { font-weight: bold; }
.j-list-item-meta { float: right; opacity: 0.7; }
.j-footer {
position: absolute;
bottom: 0.4em;
left: 0;
right: 0;
text-align: center;
font-size: 0.7em;
opacity: 0.6;
.j-body {
margin-top: 0.6em;
line-height: 1.35;
h1 { font-size: 1.4em; margin: 0.3em 0; }
h2 { font-size: 1.2em; margin: 0.3em 0; }
h3 { font-size: 1.05em; margin: 0.3em 0; }
h4, h5, h6 { font-size: 1em; margin: 0.3em 0; font-weight: bold; }
ul, ol { padding-left: 0; list-style: none; }
ul, ol { li::before { content: "β’ "; } }
ul.cb-list { li::before { content: none; } }
img { max-width: 100%; height: auto; }
</style>
<div class="view view--full">
<div class="j-layout">
{% if mode == "single" and note %}
<div class="j-title">{{ note.title }}</div>
{% if note.updated %}
<div class="j-meta">{{ note.updated }}</div>
{% endif %}
<div class="j-body">{{ note.body_html }}</div>
{% else %}
<div class="j-title">{{ title }}</div>
<div class="j-meta">{{ query }} β’ {{ count }} notes</div>
<div class="j-list">
{% for item in items %}
<div class="j-list-item">
<span class="j-list-item-title">{{ item.title }}</span>
{% if item.updated %}
<span class="j-list-item-meta">{{ item.updated }}</span>
{% endif %}
</div>
{% endfor %}
</div>
{% endif %}
</div>
<div class="j-footer">Updated {{ pushed_at }}</div>
</div>
Tips for adjusting the template:
- Headings, paragraphs, lists, blockquotes, code blocks, and other Markdown elements are styled by TRMNL's built-in framework CSS β no extra rules needed for those.
- The minimal
<style>block at the top handles two things the framework doesn't: hiding bullets on checkbox lists, and constraining image width. - If you want to override spacing or font sizes, add rules to that
<style>block targeting.note-body p,.note-body h2, etc. - Checkboxes in your notes appear as
β(unchecked) andβ(checked) inline in list items.
Compact layouts (half / quadrant)
TRMNL devices can mix multiple plugins on one screen, which uses smaller layouts: Half horizontal, Half vertical, and Quadrant. If you only use the Full layout you can skip these and ignore the "view not available" warnings. Otherwise, here are condensed templates for each.
Half horizontal:
<style>
.j-layout {
padding: 12px;
height: 100%;
font-size: 16px;
.j-title-count { font-weight: normal; opacity: 0.7; }
.j-list { margin-top: 0.4em; }
.j-list-item { padding: 0.2em 0; font-size: 1.1em; }
.j-body {
margin-top: 0.4em;
line-height: 1.3;
max-height: 180px;
overflow: hidden;
h1 { font-size: 1.4em; margin: 0.25em 0; }
h2 { font-size: 1.2em; margin: 0.25em 0; }
h3 { font-size: 1.05em; margin: 0.25em 0; }
h4, h5, h6 { font-size: 1em; margin: 0.25em 0; font-weight: bold; }
</style>
<div class="view view--half_horizontal">
{% else %}
<div class="j-title">{{ title }} <span class="j-title-count">β’ {{ count }}</span></div>
{% for item in items limit: 4 %}
<div class="j-list-item">β’ {{ item.title }}</div>
{% endfor %}
</div>
{% endif %}
</div>
</div>
Half vertical:
<style>
.j-layout {
padding: 12px;
height: 100%;
font-size: 16px;
.j-meta { font-size: 0.8em; opacity: 0.7; margin-top: 0.15em; }
.j-list-item { padding: 0.25em 0; border-bottom: 1px solid #000; }
.j-body {
margin-top: 0.6em;
line-height: 1.35;
max-height: 400px;
overflow: hidden;
</style>
<div class="view view--half_vertical">
{% endif %}
{% else %}
<div class="j-meta">{{ count }} notes</div>
{% for item in items limit: 8 %}
<div class="j-list-item">{{ item.title | truncate: 30 }}</div>
{% endfor %}
</div>
{% endif %}
</div>
</div>
Quadrant:
<style>
.j-layout {
padding: 8px;
height: 100%;
font-size: 13px;
.j-title-list { font-size: 1.4em; font-weight: bold; }
.j-list { margin-top: 0.3em; }
.j-list-item { padding: 0.15em 0; font-size: 1.1em; }
.j-body {
margin-top: 0.3em;
line-height: 1.3;
max-height: 180px;
overflow: hidden;
h1 { font-size: 1.4em; margin: 0.2em 0; }
h2 { font-size: 1.2em; margin: 0.2em 0; }
h3 { font-size: 1.05em; margin: 0.2em 0; }
h4, h5, h6 { font-size: 1em; margin: 0.2em 0; font-weight: bold; }
</style>
<div class="view view--quadrant">
<div class="j-title">{{ note.title | truncate: 60 }}</div>
{% else %}
<div class="j-title-list">{{ title }} ({{ count }})</div>
{% for item in items limit: 3 %}
<div class="j-list-item">β’ {{ item.title | truncate: 40 }}</div>
{% endfor %}
</div>
{% endif %}
</div>
</div>
Adjust font sizes, item limits, and spacing in any template if your notes are typically shorter or longer than the defaults.
Building
npm install
The plugin will be created at publish/org.joplinapp.plugins.TrmnlPlugin.jpl.
MIT
