I am very new to Markdown so have had to constantly render the Markdown to check whether my formatting is correct.
Currently to render the text on Android, the text has to be
- saved and
- the back button pressed
before the rendered markdown text can be viewed
Is it possible to use a single button to change the input text to rendered markdown and vice versa?
Just like it is implemented with the default camera app in Android, where one can easily switch between the back and front cameras with just one click.
Apologies if this feature has been requested before.
Thanks.
