Hi.I have a question.
Is it possible to use " Joplin " for business? ( production purpose )
And,Does it cost to use "Joplin " on business ?
I would appreciate it if you could tell me by using simpler words. ( I'm really sorry... )
I am not good at writing English.
I look forward to hearing from you.
Yours Sincerely,
yes
AFAIK, no, for the desktop and mobile apps.
Tagging @laurent to pls check if I'm not misleading unintentionally.
Joplin Server is not licenced for commercial use. It is covered by a personal non-commercial licence.
That's correct, all open source apps can be used for commercial purposes, with indeed the exception of Joplin Server which is personal use only.
For sync there are a number of free options, as well as self-hosting, or there's Joplin Cloud for a monthly fee.
Thank you for all reply.
it was very helpful!
Yusuke Kamata
