Hi
I was trying to sync my notes but i have this error. I dont know how to fix it. Is there a solution? Thanks in advance
Is a resource (attached file) larger than 4MB?
Known bugs
It is only possible to upload files of up to 4MB to OneDrive due to a limitation of the API being currently used. There is currently no plan to support OneDrive "large file" API.
Looks like this bug: https://github.com/laurent22/joplin/issues/2166
Please report it to Microsoft. The more people do, the more likely they’ll fix it. You can give them this link: https://github.com/laurent22/joplin/issues/2166#issuecomment-566969841
