Stackable panels
Good day!
Firs of all, I am amazed at the speed of innovation the plugin system brought to Joplin! Just super!
I am not a dev, but putting this topic here as it is mostly concerns plugin-developers. I see that new plugins take more and more room off my notes. The way to make them fit in is to make panels stackable with little thumbs on a side to navigate between them (like Obsidian but mostly like Photoshop or Gimp). Is it possible now? If not, should it be implemented? I am sure this one thing can do a lot UI-wise.
Not sure if this helps, but have you seen View > Change Application Layout? This allows you to rearrange. Won't help with tabs, but that is also a great idea!
