[SOLVED] Tips for removing safely duplicated notes from two very similar notebooks
I seek the efficient way to merge two very similar instances of same notebook that were identical till I had some synchronization problem (an old problem) and some divergence occurred between those instances. For some reason, one instance included the title in the note so that notes that are only identical in term of meaning content but they are not exactly identical in content. I was looking for a smart plugin or approach that could merge those notes automatically, but I didn't found it and was not able to program it yet. If anyone have an idea. Please share it to me. I have about 5000 notes to be merged.
The last strategy I though of is to export both instances of the notebook as markdown, compare MD directory with meld. It allows to compare notes quite fast (compared to what I could do directly in joplin). I could see if two notes with the same name are identical in meaning and choose which one I should keep. For merging or deleting duplicated notes in joplin, I first search a phrase of the note in joplin in order to identify notes. This usually gives me two notes of each instance of the notebook and I can do the correct choice manually.
I thought, I initially could manage 5000 notes in about 2-3 weeks, but it seems that I would need maybe 5 month and now I looking for a better strategy!!!
Maybe I could do some step faster by using CLI or this kind of thing that I never used. Another possibility is that, I could live with those doublons without too much disturbance.
I'm open to any suggestions that may help me solve this problems.
I use joplin-desktop-2.3.5 on archlinux.
I don't know if that would be any easier but you could try that:
  • First create a Git repository (with git init)
  • Export all your notes to it in Markdown format
  • Commit the changes (git add -A && git commit -m 'init'
  • Then export the second set of notes to it
Then using something like Sublime Merge you would directly see everything that has changed, and you can choose to stage the changes you want to keep or discard the ones you don't.
Otherwise, couldn't you just keep the most recent version of each note? Isn't it the best version in most cases? Then next to it you can maybe keep a backup of both sets so if one day you realise that something's missing you have it there.
I will try to implement the git merging approach (I've to learn some git stuffs first).
For the other suggestion based on modification time, I made unfortunately some unfortunate manipulations like exporting as markdown and importing again which make me feel that it is a bit a risky approach. I think modification date is not anymore related to editing of the notes in those notebooks.
In fact many notes have the same exact content, except the two first lines. The first line includes a date with a fixed format. The second line is empty. Maybe I could identify note/file with this characteristic, remove those lines and find identical notes after this modification, merge them. The problem is that I will lose attachements of notes that have attachements. Right? When exporting as markdown, we lose attachements?
In order to analyze the other notes I'm thinking of using python because I have some habilities with it. I think I am too weak in git, javascript and typescript. I would need quite a lot of time too learn enough in order to solve this problem.
Am I the only one having this kind of problems?
The only languages that I could use for "scripting" joplin is javascript or typescript, right?
I found that I could strip out notes with attachment by searching something like that notebook:Google_Keep_desktop resource:* and treat tese notes manually in order not to lose the attachement. I found 339 notes with attachments in one notebook and 340 in the other one. It's getting "fun"...
I finally opted for python as I know it a (little) bit more than any other options.
In order to visualize differences I use :
d = difflib.Differ()
and
diff = d.compare(text1_lines, text2_lines)
With compare it looks like that:
----------------- new comparison of possibly identical notes---------------
+ Le langage du cerveau Lionel Naccache Tête au carré
  Le système nerveux digestif est important dans la régulation des émotions et dans l'idée de soi.
  Nerf pneumo gastrique
  Il n'y a pas une région de la conscience. On n'est pas dans la phrenologie.
---------------- end of comparison of possibly identical notes---------------
The codes that I use with many limitations/bugs looks is like that (it though allows to choose which note to keep in the case of very similar notes with the same meaning content quite fast):
import difflib
from joppy.api import Api
api = Api(token='xxxxxxxx')
import getkey
# initializing things
#notebook1 = None
#notebook2 = None
#notebook_of_analizednotes_name = None
#define manually the name of notebooks of interest for merging (name is case sensitive)
#first two notebook where are to be found duplicated notes
notebook1name='Google_keep_desktop'
notebook2name='Google_keep_laptop'
#notebook were will be put the notes that will be kept
notebook_of_analizednotes_name='Google_keep_analized_via_script'
#notebook were will be put notes that in principle should and could be deleted
notebook_of_tobedeletednotes_name='Google_keep_to_be_deleted'
#get the list of id and title of all notebooks
notebooklist=api.get_notebooks(fields='id,title')['items']
#get the four dictionaries of the notebooks with the selected names
#notebookx['id'] will give the id of notebook1
#notebookx['title'] will give the title of notebook1
for notebook in notebooklist:
    if notebook['title']==notebook1name:
        notebook1=notebook
    if notebook['title']==notebook2name:
        notebook2=notebook
    if notebook['title']==notebook_of_analizednotes_name:
        notebook_of_analizednotes=notebook
    if notebook['title']==notebook_of_tobedeletednotes_name:
        notebook_of_tobedeletednotes=notebook
print("notebook1 is", str(notebook1),"\n")
print("notebook2 is", str(notebook2),"\n")
print("notebook_of_analizednotes is", str(notebook_of_analizednotes),"\n")
print("notebook_of_tobedeletednotes is", str(notebook_of_tobedeletednotes),"\n")
#for loop on the 100 notes of one notebook that contain duplicated notes
# make a query from the longuest line of the note
for note in api.get_notes(notebook_id=notebook2['id'],fields='id,title,body')['items']:
    # create a list containig all line of the note
    notelines=note['body'].split('\n')
    print("title:",note['title'],"\n","biggest ligne:",max(notelines),"\n")
    #make a search with the longest line of the note
    q='"'+max(notelines,key=len)+'"'
    print("searching for:",q)
    identicalnotes=api.search(query=q)
    #if query returns 2 or more notes then...
    if len(identicalnotes['items'])==2:
        print("\n\n\n\n\n\n----------------- new comparison of possibly identical notes---------------\n")
        note1=api.get_note(id_=identicalnotes['items'][0]['id'],fields='id,title,body')
        #list of lines of note 1
        text1_lines=note1['body'].splitlines()
        note2=api.get_note(id_=identicalnotes['items'][1]['id'],fields='id,title,body')
        #list of lines of note 2
        text2_lines=note2['body'].splitlines()
        #compare notes and give a representation of the difference beetween notes
        print('\n'.join(diff))
        print("\n---------------- end of comprison of possibly identical notes---------------\n\n")
        while 1:
            print("""
            choose your option:
            1: note 1 -> analized notebook
               note 2 -> tobedeleted notebook
               analize next note
            2: note 2 -> analized notebook
               note 1 -> tobedeleted notebook
               analize next note
            3: do not modify note and analize next note
               analize next note
            key = getkey.getkey()
            if key == '1':
                print('note 1 -> analized notebook')
                #move note1 to analized notebook
                api.modify_note(id_=note1['id'], parent_id=notebook_of_analizednotes['id'])
                print('note 2 -> tobedeleted notebook')
                #move note2 to tobedeleted notebook
                api.modify_note(id_=note2['id'], parent_id=notebook_of_tobedeletednotes['id'])
                print('analizing next note')
                break
            elif key == '2':
                print('note 1 -> tobedeleted notebook')
                #move note1 to tobedeleted notebook
                api.modify_note(id_=note1['id'], parent_id=notebook_of_tobedeletednotes['id'])
                print('note 2 -> analized notebook')
                api.modify_note(id_=note2['id'], parent_id=notebook_of_analizednotes['id'])
                break
            elif key == '3':
                break
With this script with small modifications, I was able to strip down from about 5000 notes to about 170 notes in few days. The remaining possibly replicated notes are notes that have attachment and need a little bit more code. I've to do some research on how to compare attachments in order to check if notes are identical including the attachment.
Here is the last script I used. Someone may be interested in adapting it for its own reality. It helped me a lot accelerating the cleaning of doublons. It shows a diff file that allows to check if two similar files are semantically identical. In case of necessity of merging, I used meld e did manually merging in joplin. I could clean about 5000 doublons in maybe about 10-15 hours.
import difflib
api = Api(token='b654d8fb77bc7a32ea15033339ae8f94192434076ac0e59f1c4839e6c131b26dd95275e655a557cc8217c561647968835e28a2a4bf9ea2cbcc6ceb9cd02e0516')
import getkey
import re
notebook_of_analizednotes_name='Google_keep_analized_notes'
#notebooklist is such that:
#notebooklist[0]['id']    give the id    of the first notebook
#notebooklist[0]['title'] give the title of the first notebook
#select the notebook for which you want to see if it contains notes that are duplicated
#and select the notebook in which you want to put the note after managing it (notebook_of_analizednotes
# logic: if note have no doublon but
print("list of notebooks are the following:\n")
for i,notebookdic in enumerate(notebooklist):
    print(i,' ',notebookdic['title'])
#ask name of notebooks
#notebook1name=input('give the name of the notebook for which in you want to check if notes inside it have doublons:\n')
#notebook_of_analizednotes_name=input('give the name of the notebook in which you will put anotation that will be kept:\n')
#notebook_of_tobedeletednotes_name=input('give the name of the notebook in which you will put anotations that will not be kept:\n')
notebook1name='Google_Keep_desktop_attachement'
notebook_of_analizednotes_name='Google_Keep_laptop_analized_attachement'
########## parei aqui no 08/11/2021
for notebookdic in enumerate(notebooklist):
    if notebookdic[1]['title']==notebook1name:
        notebook1=notebookdic[1]
    if notebookdic[1]['title']==notebook_of_analizednotes_name:
        notebook_of_analizednotes=notebookdic[1]
    if notebookdic[1]['title']==notebook_of_tobedeletednotes_name:
        notebook_of_tobedeletednotes=notebookdic[1]
#loop on all notes of notebook2
for note in api.get_all_notes(notebook_id=notebook1['id'],fields='id,title,body'):
    # create a list containig all line of the note removing some special characteres
    notelines=note['body'].replace('(',' ').replace(')',' ').replace('[',' ').replace(']',' ').replace('"',' ').replace('&',' ').replace('#',' ').replace('%',' ').replace('.',' ').split('\n')
    # abandonned approach:
    #notelines=re.split(r'[`\-=~!@#$%^&*()_+\[\]{};\'\\:"|<,./<>?]', note['body'])
    q=max(notelines,key=len)
    #adding " in order to get a correct search query
    print("number of notes:",len(identicalnotes['items']))
    #printing all notes in order to see note titles
    print("identical notes:")
    for identicalnote in identicalnotes['items']:
        print(identicalnote)
    #if a single note is found
    if len(identicalnotes['items'])==1:
        #move not duplicated notes to the notebook of analyzed notes
        api.modify_note(id_=identicalnotes['items'][0]['id'], parent_id=notebook_of_analizednotes['id'])
    if len(identicalnotes['items'])>2:
        print("they are more than 2 notes at this point")
        # reduce note list to note that are in the two notebooks were notes have to be analized:
        identicalnotes2=[i for i in identicalnotes['items'] if (i['parent_id']=='dfa6f637732f4d318b4fcf21b05aa6af' or i['parent_id']=='8b31a7b0486a453fb425516432a96225' )]
        print("identical notes that have not yet been analized:")
        for i,identicalnote in enumerate(identicalnotes2):
            print(i, identicalnote)
        while 1:
            print("""
            choose your option :
            Press Enter twice -> do nothing
            Press numbers of two notes -> compare these notes
            key1 = getkey.getkey()
            key2 = getkey.getkey()
            if key1 == '\n':
                break
            elif key1 != key2:
                #a preencher
                #substitute identicalnotes['items'][0]['id'] by identicalnotes['items']
                note1=api.get_note(id_=identicalnotes2[int(key1)]['id'],fields='id,title,body')
                note2=api.get_note(id_=identicalnotes2[int(key2)]['id'],fields='id,title,body')
                bodiescompare='\n'.join(diff)
                # choose only "+ notes" or "- notes"
                #if bodiescompare.splitlines()[0][0]=='-' and bodiescompare.splitlines()[0][0]=='-':
                #if bodiescompare.splitlines()[0][0]=='+' and bodiescompare.splitlines()[0][0]=='+':
                print(bodiescompare)
                while 1:
                    print("""
                    choose your option:
                    analize next note
                    analize next note
                    analize next note
                    key3 = getkey.getkey()
                    if key3 == '1':
                        break
                    elif key3 == '2':
                        break
                    elif key3 == '3':
                        break
                #print('note 1 -> analized notebook')
                #api.modify_note(id_=note1['id'], parent_id=notebook_of_analizednotes['id'])
                #print('note 2 -> tobedeleted notebook')
                #api.modify_note(id_=note2['id'], parent_id=notebook_of_tobedeletednotes['id'])
                #print('analizing next note')
                break
            elif key1 == key2:
                identicalnotes['items'](key1)
                identicalnotes['items'].pop(key1)
                print("list of identical notes are now:")
                #print('note 1 -> tobedeleted notebook')
                #api.modify_note(id_=note1['id'], parent_id=notebook_of_tobedeletednotes['id'])
                #print('note 2 -> analized notebook')
                #api.modify_note(id_=note2['id'], parent_id=notebook_of_analizednotes['id'])
                break
            elif key == '3':
                identicalnotes['items'].pop()
                break
            elif key == '4':
                break
        #q=input()
        #identicalnotes=api.search(query=q)
        # new ideas to develop:
        #print("they are more than 2 notes. Cycling through notes in order to find possibly some search query that can be addressed fast---")
        #for note2 in identicalnotes['items']:
        #    notelines=re.split(r'[`\-=~!@#$%^&*()_+\[\]{};\'\\:"|<,./<>?]', note2['body'])
        #    q=max(notelines,key=len)
        #    identicalnotes=api.search(query=q)
        #else:
        #    print("could strip down to 2 notes")
        #q não é vazia pode tentar a comparação de anotações
        #if len(q)>10:
        #    ok=1
        #    q='"'+q+'"'
        #starting comparison of 2 notes and printing
        while 1:
            print("""
            choose your option:
            analize next note
            analize next note
            analize next note
            if key == '1':
                break
            elif key == '2':
                break
            elif key == '3':
                break
Nice that you got there eventually, it looks like was quite some work!
Yes, It was for me quite a bit of work but it was finally easier than what I thought initially. The python difflib did helped me. It made it possible to see immediatly that two notes are semantically identical in my cases. For bigger note, I just had to scroll bit so that 2 or 3 second were sufficient. With the getkey llib that gets automatically keyboard input, I could make an almost immediate decision. I may say, it was almost fun. I have to keep programming every 2 or 3 years in order not to forgot everything!
