I was wondering whether there is a shortcut to enter a todo-list in markdown. On the other hand the experience could be improved if shortcuts where mentioned within the tooltips inside the editor.
Thanks,
P
Thanks,
P
There isn't one at the moment, even though it would be cool feature to have.
btw, welcome to the forum, P
Hi, thanks for getting back. I would then like to turn this into a feature request. My suggestion would be cmd+enter; that's at least what most other note taking apps use.
I assume that it's also not possible to individually set that as a shorcut?
Well, this shortcut is currently occupied by rich markdown "Perform action".
I would personally suggest to reuse keymapping of google docs and tinyMCE (which we already use)
Ctrl + Shift + 9
