Shortcut for moving back/forward between notes
Joplin version: 2.8.7 (prod, linux); Revision: c2a6a13
OS: Ubuntu 22.04.1 LTS
I am unable to find the shortcuts for moving backwards/forwards between notes. So in essence a shortcut for the left-/right-arrows in the navigation bar on the left in this screenshot:
Is there a shortcut or can I configure it?
It's Shift+Cmd+Left (or Right) by default, but you can change that in the settings. Search for "back" and "forward".
Thank you. This solved the issue. I found that the corresponding shortcuts were not defined, so I had to set them, which worked as expected.
