In developer mode, you can install an extension by selecting a whole directory that contains the source codes for the extension.
However, the app-clipper directory contains node modules, which altogether make it weigh more than 160mb.
There doesn't seem to exist a script that generates a lean, optimized folder that contains only the files the the browser needs.
My question is: Am I missing something? If not, is there a need for such a script to speed up the development process of the Joplin clipper. What I have on mind is a script that will create a dist directory and copy the following files to this directory:
- the background and content scripts
- the
builddirectory of thepopup - manifest.json
- the
iconsfolder
On testing, this dist folder weighs less than 1Mb, a step up from the 160mb original folder.
Every time you make some changes to any of the files above, you can run the script again to create a brand new, updated dist folder. Then in the Extensions Settings page, simply click the Reload link to update the extension in development mode.
