Saving Mermaid generated Images
Joplin 2.9.17 (prod, darwin)
Client ID: b39a3c44d4d14d93a0ab5aa463ccafbd
Profile Version: 41
Revision: a84a8e7
I'm trying to save images generated via mermaid plug-in. When I save the file as 'png' or 'svg', the output is not usable. Are there plans to fix the issue ? The only option i have at the moment is to screen capture the output but that has it's own limitation (example, resizing the output to fit the screen is not problematic).
thanks.
I think this is fixed in this commit
You need to download v2.10.6 or higher version to get this fix.
(v2.10.x are all pre-releases now.)
