Removing Jarvis from Joplin
Joplin 3.4.12 (prod, win32)
Device: win32, Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
Client ID: 59aff23ef81a4a0b9f7275abfd496c8d
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
Backup: 1.4.3
Freehand Drawing: 3.1.0
Jarvis: 0.12.0
Please excuse my total ignorance of Joplin, Jarvis, and this website. I have been using Joplin for about 2 months after moving from Evernote. I decided that installing Jarvis would help in my searches of my notes. Unfortunately, I installed Jarvis without any understanding of what was involved. Now my installation is incomplete and I've disabled Joplin in the process. When I open Joplin, it displays a message: "Please specify a valid OpenAI API key in the settings". I click OK, but then Joplin closes. At this point, I just want to remove Jarvis and be able to use Joplin again. Again, I apologize for my total ignorance. Please help!
Are you referring to Jarvis that’s in the MS store?
AI assistant?
Hi @rcrow490, Jarvis dev here. I've never encountered this issue (Joplin crashing), but first I'll try to help you remove the plugin.
  • To uninstall the plugin in this case: Try to start Joplin in safe mode (no plugins active). Go to Settings -> Plugins and delete Jarvis.
  • If you have access to your logs and crash reports, sharing them may help identifying the problem.
  • If you do decide to give the plugin a try in the future, try to follow these instructions. You are also welcome to post questions in this plugin thread or issues on GitHub.
