macOS
Joplin 3.3.5 (prod, darwin)
Device: darwin, arm64
Client ID: 8e74f3b26f2644539505e1d7ce930bb8
Alternative instance ID: -
Revision: b3a3690
ABC Sheet Music Plugin: 1.0.5
Backup: 1.4.2
Csv Import: 1.0.1
Delete unlinked resources: 1.0.0
Extra Markdown editor settings: 1.10.1
Favorites: 1.3.2
Freehand Drawing: 3.0.1
Github Alerts: 1.0.5
Templates: 2.4.0
Joplin Cloud
Hi all,
Recently I tried setting up a joplin server of my own, as an experiment. Now I've moved back to joplin cloud, but I'm experiencing a problem. The desktop app now refuses to sync. I go in to authorise, it successfully redirects to the Joplin Cloud authorisation screen, I authorise and move back to the app. It spins the wheel for a while and eventually, I get the below error:
You were unable to connect to Joplin Cloud. Please check your credentials and try again. Error:request to https://api.joplincloud.com/api/sessions failed, reason:
(Obviously, there's no reason provided).
Any ideas what's going on?
