Problem Katex render, windows
Hi there,
i have a problem with
Joplin 1.0.195 (prod, win32)
Client-ID: 7bc0bd749f5f432487ad7d492d508a84
Sync-Version: 1
Profil-Version: 28
Revision: f4a562bc (master)
PROBLEM
Formulas after something else will get rendered two times (see my pictures).
If i type in two formulas in a row, then the first one is rendered two times and the second formula is rendered correct.
The problem doesnt appear within tables.
Greetings!
I believe this is a known issue, which will be fixed in the next release.
Thanks for your answer.
Indeed, the next update solved the problem:)
