I am facing problems in building the app from source
prebuild-install WARN install No prebuilt binaries found (target=14.11.0 runtime=node arch=x64 libc= platform=linux)
Package libsecret-1 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libsecret-1.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libsecret-1' found
gyp: Call to 'pkg-config --libs-only-l libsecret-1' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:314:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
gyp ERR! System Linux 5.4.0-48-generic
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/koushik/Documents/code/git-repo/joplin/ElectronClient/node_modules/keytar
gyp ERR! node -v v14.11.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-win@2.2.0 (node_modules/7zip-bin-win):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-win@2.2.0: wanted {"os":"win32","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-mac@1.0.1 (node_modules/7zip-bin-mac):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-mac@1.0.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/glob-watcher/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.0 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/babel-cli/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! keytar@5.6.0 install: `prebuild-install || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the keytar@5.6.0 install script.
npm ERR! /home/koushik/.npm/_logs/2020-09-18T04_10_27_987Z-debug.log
npm ERR! errno 1
npm ERR! joplin@1.0.0 postinstall: `cd Tools && npm i && cd .. && cd ReactNativeClient && npm i && cd .. && cd ElectronClient && npm i && cd .. && cd CliClient && npm i && cd .. && gulp build`
npm ERR!
npm ERR! Failed at the joplin@1.0.0 postinstall script.
npm ERR! /home/koushik/.npm/_logs/2020-09-18T04_10_29_019Z-debug.log
When I run the command npm install I am getting these errors. Then when I go to ElectronClient and run npm start I get the following errors:
/home/koushik/Documents/code/git-repo/joplin/ElectronClient/node_modules/electron/index.js:14
throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
at getElectronPath (/home/koushik/Documents/code/git-repo/joplin/ElectronClient/node_modules/electron/index.js:14:11)
at Object.<anonymous> (/home/koushik/Documents/code/git-repo/joplin/ElectronClient/node_modules/electron/index.js:18:18)
at Module._compile (internal/modules/cjs/loader.js:1076:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
at Module.load (internal/modules/cjs/loader.js:941:32)
at Function.Module._load (internal/modules/cjs/loader.js:782:14)
at Module.require (internal/modules/cjs/loader.js:965:19)
at require (internal/modules/cjs/helpers.js:88:18)
at Object.<anonymous> (/home/koushik/Documents/code/git-repo/joplin/ElectronClient/node_modules/electron/cli.js:3:16)
npm ERR! errno 1
npm ERR! Joplin@1.1.2 start: `gulp build && electron . --env dev --log-level debug --no-welcome --open-dev-tools`
npm ERR!
npm ERR! Failed at the Joplin@1.1.2 start script.
npm ERR! /home/koushik/.npm/_logs/2020-09-18T04_16_00_582Z-debug.log
Please help
