Whoops, somehow I pasted the wrong thing. This is the error:
npm ERR! code 1
npm ERR! path /bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3
npm ERR! command failed
npm ERR! command sh -c node-pre-gyp install --fallback-to-build
npm ERR! make: Entering directory '/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/build'
npm ERR! ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c
npm ERR! TOUCH Release/obj.target/deps/action_before_build.stamp
npm ERR! CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3280000/sqlite3.o
npm ERR! AR(target) Release/obj.target/deps/sqlite3.a
npm ERR! COPY Release/sqlite3.a
npm ERR! CXX(target) Release/obj.target/node_sqlite3/src/backup.o
npm ERR! make: Leaving directory '/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/build'
npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/lib/binding/node-v102-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/lib/binding/node-v102-linux-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v102' (1)
npm ERR! node-pre-gyp info it worked if it ends with ok
npm ERR! node-pre-gyp info using node-pre-gyp@0.11.0
npm ERR! node-pre-gyp info using node@17.3.1 | linux | x64
npm ERR! node-pre-gyp WARN Using request for node-pre-gyp https download
npm ERR! node-pre-gyp info check checked for "/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/lib/binding/node-v102-linux-x64/node_sqlite3.node" (not found)
npm ERR! node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.0/node-v102-linux-x64.tar.gz
npm ERR! node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.0/node-v102-linux-x64.tar.gz
npm ERR! node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.0/node-v102-linux-x64.tar.gz
npm ERR! node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.0 and node@17.3.1 (node-v102 ABI, glibc) (falling back to source compile with node-gyp)
npm ERR! node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.0/node-v102-linux-x64.tar.gz
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@8.4.1
npm ERR! gyp info using node@17.3.1 | linux | x64
npm ERR! gyp info ok
npm ERR! gyp info find Python using Python version 3.10.2 found at "/usr/bin/python3"
npm ERR! gyp http GET https://nodejs.org/download/release/v17.3.1/node-v17.3.1-headers.tar.gz
npm ERR! gyp http 200 https://nodejs.org/download/release/v17.3.1/node-v17.3.1-headers.tar.gz
npm ERR! gyp http GET https://nodejs.org/download/release/v17.3.1/SHASUMS256.txt
npm ERR! gyp http 200 https://nodejs.org/download/release/v17.3.1/SHASUMS256.txt
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/usr/lib/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3/build/config.gypi',
npm ERR! gyp info spawn args '/usr/lib/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/thayne/.cache/node-gyp/17.3.1/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/thayne/.cache/node-gyp/17.3.1',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/home/thayne/.cache/node-gyp/17.3.1/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/bulk/home/thayne/devel/aur2/joplin-full/src/joplin-2.6.10/packages/server/node_modules/sqlite3',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘strftimeFunc’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:14137:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type]
npm ERR! 14137 | #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize)
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:22052:52: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 22052 | z==zBuf ? SQLITE_TRANSIENT : SQLITE_DYNAMIC);
npm ERR! | ^~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3ErrorWithMsg’:
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:30393:54: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 30393 | sqlite3ValueSetStr(db->pErr, -1, z, SQLITE_UTF8, SQLITE_DYNAMIC);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3VdbeMemSetStr’:
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:75499:15: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 75499 | if( xDel==SQLITE_DYNAMIC ){
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘valueFromExpr’:
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:75905:55: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 75905 | sqlite3ValueSetStr(pVal, -1, zVal, SQLITE_UTF8, SQLITE_DYNAMIC);
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:75948:29: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 75948 | 0, SQLITE_DYNAMIC);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3VdbeExec’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:91000:38: warning: cast between incompatible function types from ‘int (*)(u32, void *, void *, void *)’ {aka ‘int (*)(unsigned int, void *, void *, void *)’} to ‘void (*)(void *, const char *)’ [-Wcast-function-type]
npm ERR! 91000 | void (*x)(void*,const char*) = (void(*)(void*,const char*))db->xTrace;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3DefaultRowEst’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:110505:3: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
npm ERR! 110505 | if( pIdx->pPartIdxWhere!=0 ) a[0] -= 10; assert( 10==sqlite3LogEst(2) );
npm ERR! | ^~
npm ERR! In file included from Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:13656:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:110505:45: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
npm ERR! | ^~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:110506:3: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
npm ERR! 110506 | if( a[0]<33 ) a[0] = 33; assert( 33==sqlite3LogEst(10) );
npm ERR! | ^~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:110506:45: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
npm ERR! | ^~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘printfFunc’:
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:113251:25: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 113251 | SQLITE_DYNAMIC);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘generateColumnNames’:
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:126515:58: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 126515 | sqlite3VdbeSetColName(v, i, COLNAME_NAME, zName, SQLITE_DYNAMIC);
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:126522:52: note: in expansion of macro ‘SQLITE_DYNAMIC’
npm ERR! 126522 | sqlite3VdbeSetColName(v, i, COLNAME_NAME, z, SQLITE_DYNAMIC);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3InvokeBusyHandler’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:156204:12: warning: cast between incompatible function types from ‘int (*)(void *, int)’ to ‘int (*)(void *, int, sqlite3_file *)’ [-Wcast-function-type]
npm ERR! 156204 | xTra = (int(*)(void*,int,sqlite3_file*))p->xBusyHandler;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3_busy_timeout’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:156282:30: warning: cast between incompatible function types from ‘int (*)(void *, int, sqlite3_file *)’ to ‘int (*)(void *, int)’ [-Wcast-function-type]
npm ERR! 156282 | sqlite3_busy_handler(db, (int(*)(void*,int))sqliteDefaultBusyCallback,
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3_trace’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:156623:16: warning: cast between incompatible function types from ‘void (*)(void *, const char *)’ to ‘int (*)(u32, void *, void *, void *)’ {aka ‘int (*)(unsigned int, void *, void *, void *)’} [-Wcast-function-type]
npm ERR! 156623 | db->xTrace = (int(*)(u32,void*,void*,void*))xTrace;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3_db_status’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:20875:10: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 20875 | op = SQLITE_DBSTATUS_CACHE_WRITE+1;
npm ERR! | ~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:20877:5: note: here
npm ERR! 20877 | case SQLITE_DBSTATUS_CACHE_HIT:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3_str_vappendf’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:27625:19: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 27625 | flag_long = sizeof(char*)==sizeof(i64) ? 2 :
npm ERR! | ~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! 27626 | sizeof(char*)==sizeof(long int) ? 1 : 0;
npm ERR! | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:27628:7: note: here
npm ERR! 27628 | case etORDINAL:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:27630:19: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 27630 | cThousand = 0;
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:27632:7: note: here
npm ERR! 27632 | case etDECIMAL:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3GetToken’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:153777:9: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 153777 | if( !sqlite3Isdigit(z[1]) )
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:153786:5: note: here
npm ERR! 153786 | case CC_DIGIT: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:153876:9: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 153876 | if( z[1]=='\'' ){
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:153890:5: note: here
npm ERR! 153890 | case CC_ID: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3ExprCodeTarget’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:100345:25: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 100345 | case TK_AGG_COLUMN: {
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:100358:5: note: here
npm ERR! 100358 | case TK_COLUMN: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘resolveP2Values’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:77052:13: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 77052 | if( pOp->p2!=0 ) p->readOnly = 0;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:77055:9: note: here
npm ERR! 77055 | case OP_AutoCommit:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:77093:26: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 77093 | case OP_VFilter: {
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:77102:9: note: here
npm ERR! 77102 | default: {
npm ERR! | ^~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘resolveExprStep’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:96041:20: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 96041 | case TK_ISNOT: {
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:96057:5: note: here
npm ERR! 96057 | case TK_BETWEEN:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘impliesNotNullRow’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:101891:8: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 101890 | if( (pExpr->pLeft->op==TK_COLUMN && IsVirtual(pExpr->pLeft->y.pTab))
npm ERR! | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! 101891 | || (pExpr->pRight->op==TK_COLUMN && IsVirtual(pExpr->pRight->y.pTab))
npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:101895:5: note: here
npm ERR! 101895 | default:
npm ERR! | ^~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘fkActionTrigger’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:116360:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 116360 | if( !pChanges ){
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:116364:7: note: here
npm ERR! 116364 | default:
npm ERR! | ^~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3GenerateConstraintChecks’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:117819:17: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 117819 | onError = OE_Abort;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:117823:7: note: here
npm ERR! 117823 | case OE_Abort:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:117981:17: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 117981 | onError = OE_Abort;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:117984:7: note: here
npm ERR! 117984 | case OE_Rollback:
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:118044:9: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 118044 | sqlite3UpsertDoUpdate(pParse, pUpsert, pTab, 0, iDataCur);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:118048:7: note: here
npm ERR! 118048 | case OE_Ignore: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:118260:9: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 118260 | sqlite3UpsertDoUpdate(pParse, pUpsert, pTab, pIdx, iIdxCur+ix);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:118264:7: note: here
npm ERR! 118264 | case OE_Ignore: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:84544:5: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 84544 | if( (pIn3->flags & MEM_Null)==0 ) break;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:84578:1: note: here
npm ERR! 84578 | case OP_Halt: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:84711:5: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 84711 | if( pOp->p1>db->aLimit[SQLITE_LIMIT_LENGTH] ){
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:84730:1: note: here
npm ERR! 84730 | case OP_String: { /* out2 */
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:87786:19: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 87786 | case OP_IfNoHope: { /* jump, in3 */
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:87794:1: note: here
npm ERR! 87794 | case OP_NoConflict: /* jump, in3 */
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:88710:38: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 88710 | p->aCounter[SQLITE_STMTSTATUS_SORT]++;
npm ERR! | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:88725:1: note: here
npm ERR! 88725 | case OP_Rewind: { /* jump */
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:90021:15: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 90021 | pOp->opcode = OP_AggStep1;
npm ERR! | ^
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:90024:1: note: here
npm ERR! 90024 | case OP_AggStep1: {
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:90893:15: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 90893 | pOp->opcode += 2;
npm ERR! | ~~~~~~~~~~~~^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:90896:1: note: here
npm ERR! 90896 | case OP_PureFunc: /* group */
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘fts3SnippetFunc’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163899:22: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 163899 | case 6: nToken = sqlite3_value_int(apVal[5]);
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163900:5: note: here
npm ERR! 163900 | case 5: iCol = sqlite3_value_int(apVal[4]);
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163900:20: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163901:5: note: here
npm ERR! 163901 | case 4: zEllipsis = (const char*)sqlite3_value_text(apVal[3]);
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163901:38: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163902:5: note: here
npm ERR! 163902 | case 3: zEnd = (const char*)sqlite3_value_text(apVal[2]);
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163902:33: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163903:5: note: here
npm ERR! 163903 | case 2: zStart = (const char*)sqlite3_value_text(apVal[1]);
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘fts3ColumnMethod’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163656:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 163656 | iCol = p->nColumn;
npm ERR! | ~~~~~^~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:163660:5: note: here
npm ERR! 163660 | default:
npm ERR! | ^~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘cellArea’:
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:183145:22: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! 183145 | case 5: area = p->aCoord[9].f - p->aCoord[8].f;
npm ERR! | ~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:183146:7: note: here
npm ERR! 183146 | case 4: area *= p->aCoord[7].f - p->aCoord[6].f;
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:183146:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
npm ERR! | ~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:183147:7: note: here
npm ERR! 183147 | case 3: area *= p->aCoord[5].f - p->aCoord[4].f;
npm ERR! | ^~~~
npm ERR! Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:183147:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
