Hi @joplin_user, I'm sorry to leave and thank you for all the time of your support. I'm leaving because I'm looking for an app that can provide better cross platform experience, and my pick is a web3-based Notion-like app - Anytype. It does not have as many features as Joplin, nor is it as easy to use as Notion, but it has reliable privacy & security and better cross-platform experience. So, I chose it doesn't mean it was particularly good, it was just based on a comprehensive balance of personal needs.
Sad news, @Sinacs ![]()
Many thanks for the great job you have done, first with Ohmine Dark Theme, then with Remoods. I used them from the very beginning. I hope someone will follow up.
Good luck with your next projects ![]()
Just discovered that beautiful plugin and at the same time that it was abandoned... What a pity ![]()
Thank you so @Sinacs for creating and sharing it ![]()
Hope someone will take over ![]()
Maybe some of you guys may be able to help me nevertheless...
I only have a few of issues and improvements that I could hopefully fix myself with a bit of guidance:
In editor: increase the font size of the text part in links in titles/make in the same as title font size, actually
Edit: on second sight, it looks like the links text get a smaller font size everywhere -
Size of 'New note' and 'New task' buttons at the top of the notes list
Remove highlighting of italic, bold and inline code
Thanks in advance
There are also some issues with the toolbar, this fork has work it around:
By the way, I'm still optimistic that the 'Anytype' will eventually let @Sinacs down, paving the way for the revival of this fantastic plugin. Fingers crossed!
The new Joplin release 3.0 gives me an issue with notebooks in Remoods, @Sinacs or Suzanne would it be possible for a fix in the GitHub - SuzanneHuang/Joplin.Plugin.ReMoods.Theme fork?
Notebooks do not roll out
Yeah, I was saddened to see this too, Remoods really makes it look way better. Hoping someone can figure out a fix.
This repo was updated yesterday with a notebook fix, but I haven't been able to get it.
SuzanneHuang's fork has now been updated with a fix for the notebook list! Yay!
Im really glad SuzanneHuang patched this plugin a few times, I hope it doesn't get left behind with the Joplin 3.0 changes.
Everything seems to be working well with the notebook panel and note list, but the Markdown editor pane now seems to be buggy in my app. The markdown headings are normally enlarged according to their level (H1, H2, etc...). However, now they are all left as normal text size, which loses some of its visual separation. The headings show up as you would expect in the rendered markdown, which I suppose is the important part, but it is a sorely missed visual effect in the editor pane.
Has anyone else noticed this, or perhaps know of a fix? Ive tried tinkering around with the CSS files, but I don't know enough to really make a difference there.
It needs to be published again under a different ID
@silopolis the best would be, if Suzanne were able to get in contact with the original dev and took over the plugin.
If that is not possible, Suzanne should fork the repo, change the plugin id, and rename the plugin to ReMoods Theme v2 (or whatever differentiates it to the original).
I love the remoods theme! But I want to know if there is a way to disable the settings of exporting in plugin, because I want to use my customized exporting css config.
