Plugin: Emoji Picker
Plugin seems to be broken for me. I can't trigger the popup.
It should be fixed by now. It seems that the module I am using to generate the HTML is not packed correctly into the jpl file. It works in dev environment before and I didn't see this coming.
Thank you for your reply, shbach!
Thanks! I posted a feature request on this months ago:
https://discourse.joplinapp.org/t/emoji-auto-completion-plugin-request/20932?u=novelx and am happy to have it.
But It doesn't show the popup, actually, nothing happened. Is this the version that was not packed correctly you mentioned above?
macOS, plugin v1.0.2
Yes, I've fixed it in v1.0.3. You can upgrade to solve this problem. Thx for your support!
I was very happy to find this plugin, but the emoji list is not showing up. I'm using version 1.0.4 on Joplin on Linux Mint 21, all up-to-date, and had chosen :: a trigger. Any idea?
The same.
It's a pity that a lot of topics are closed without answer.
You might create an issue directly at Github, but it seems there is no activity anymore in this case :frowning:
