Other great note takers and points for improvement for Joplin
Very pleasant editor, handles everything very nicely, tables, theming, outline, etc.
Very user friendly
That would be very interesting indeed. The user experience is excellent. The appearance of the menus, the full screen mode... very good. In addition, it is excellent that the backlinks give the context of the sentence in which the reference is found.
Yeah, that's one of the few things I think Joplin could improve upon.... even with the awesome Rich Markdown plugin. Agree with you both... wish Joplin had a similar experience, editor wise :slight_smile:
Love how you can create tables, code etc with just one button push. Am I correct that there is no support for images though? I see some menu options so I might have missed it, I don't speak Chinese I'm afraid.
Try pasting the following markdown in to the editor.
![some](https://raw.githubusercontent.com/laurent22/joplin/dev/Assets/LinuxIcons/256x256.png)
It looks like the little cloud icon is the attach feature, but it's disabled for the demo.
Nice! Really like that editor :smiley:
There are a few things I missed from Evernote when I started using Joplin. Two concerned being able to compare the information from multiple notes. The first was the lack of detachables notes, but that could be worked around by using external editors. The second concerned the lack of Evernote's view options for the note list, specifically the snippet view which might be similar to what you're looking for:
That's the sort of enhancement provided by plugins in Joplinland. @mablin7's Kanban Board Project springs immediately to mind as an example.
I agree it's a matter of individual preference, and Markdown wasn't really created with indented outlines in mind. @laurent's use of tab indenting makes perfect sense if you're editing notes as text, but that information gets lost in the rendering. For my purposes adding [TOC] and different levels of headings is sufficient as it allows me to navigate when I'm using a rendered note for reference.
Reminder: Siyuan is private, not open source. Siyuan's editor (vditor) is open source. Second, Siyuan notes are great.
I can speak a little Chinese, and language translation is not very difficult. For example, I am using Google Translate to communicate with you.
I also tried it without any problem. For me, the interface was not too complicated. What I had problems with was that Markdown support was severely limited, there was no syntax highlighting in code blocks, there was no typescript between code type elements, server-side javascript could be run, but console.log did nothing.
What was nice about it was the code block execution option, I would like to see something like that in Joplin. Especially if it would be complemented with python, there are js libraries that allow this, e.g. brpython.
What it really wasn't was the markdown handling, and that there was no mobile version.
Are y'all talking about this editor?
Because I've opened it just now and only tried 2 things; one didn't work, and the other outright garbled my text. I'm not very impressed.
Update: like this.
vditor
That's been my experience too when looking a bit more closely at these editors. I've reviewed quite a few when I've implemented the Rich Text editor and they are all a bit like this. They have nice, impressive demos, but you often find all kind of limitations that makes them hard to use in a real app.
And I didn't check the API or doc, but usually they are not good enough to support what we need (in particular with regards to attachments, note links, code blocks, katex, etc.).
I also passed Trilium on my long walk to Joplin.
I was put off by the nerdy UI and also the lack of mobile apps.
But..as mentioned here before, a card view mode would really be a great addition to Joplin.
This allows for a very quick overview and visual prorization and curodization of notes.
This efficient overview would otherwise, be one of the few things I will miss when I will have completely switched from Google Notes (Keep) to Joplin.
Thanks for considering this feature!
index
I have been giving some thought about card view and I think @JackGruber 's work on the plugin note overview might be the solution to achieving this. I have already been able to achieve this thanks to some new updates on the note over view plugin:
My plan is that instead of using <details> tag I might able to use a custom html tag with some custom css to display note overview as cards. I just need a few hours to try things out.
I am quite happy with the editor in the desktop versions. However, the mobile editors would be easier to use with some more functions. On the one hand I think of some kind of a toolbar above the keyboard. Like it is visible in the screenshots of the MDNotes App (IOS). For android I think a good app for comparison is Markor. MDNotes is to my knowledge not open source and Markor is written in Java. Both of them interact directly with the filesystem.
Ipad Mini Landscape
Iphone SE Portrait
A toolbar with quick camera/photos access could come in very handy as iOS15 supports OCR (Live Text, only supported in newer devices) in the camera/photos app. As Markor seems to have a toolbar too, I assume there is a way to implement something in all mobile versions.
Maybe there is also already a custom made keyboard around that makes it easier to type markdown on mobile? Though, in terms of style it would most likely look better if it is from Joplin itself.
On the other hand I am missing a faster navigation on tablets in landscape orientation (notebooks -> note -> open/edit). A fixed notes sidebar would improve usability on tablets in landscape orientation. For the portrait mode and on too small devices I don't think a change of behavior would be helpful. Maybe there were already considerations or there are reasons why this was not implemented.
To continue the discussion somewhat in regards to markdown editors, I recently came across Cherry Editor the other day which piqued my interest.
It doesn't appear that it can currently support a full WYSIWYG experience but from a markdown editor p
perspective it features a bunch of features that I really quite like (there are some interactive demos if you should want to have a look - most of the links below go to the demo and to the interactive section I'm talking about although you might have to hit return on the URL bar a second time to get it scroll there for some reason)
Markdown
  • Quick font styling syntax (Cherry Editor - Markdown Editor).
    It uses its own markdown syntax of ! text !. e.g
    • !32 text! will set the rendered size of "text" to 32 pt
    • !!#ff0000 text!! will set the font colour to red
    • !!!#000000 text!!! will set the background colour to black.
      These can also be combined so you could have big red text on a black background by writing !32 !!#ff0000 !!!#000000 text !!!!!!
      This font styling is also supported by a 2 pane colour picker from the toolbar and it can be inserted within other markdown tags (for example in a URL)
  • Markdown image manipulation syntax (Cherry Editor - Markdown Editor)
    • Adds syntax to the image tag for sizing, positioning etc e.g ![dog#auto#100px#left](images/demo-dog.png)
    • When the image is manipulated on the preview pane, the size values etc. will change on the markdown editor (Cherry Editor - Markdown Editor)
  • Inbuilt diagram support (mermaid etc.) (Cherry Editor - Markdown Editor)
Thoughts
The editor looks nice and seems to behave quite nicely. It does appear to be very new so I've had a couple of janky experiences but nothing major.
The obvious problem I see here is the extended "CherryMarkdown" syntax not being compatible with other markdown flavours. I suppose there could always be a conversion routine when exporting to markdown that could strip the extended syntax away to make it compatible again.
The dynamic image resizing is something that I personally would find really helpful in Joplin when trying to import photos etc that don't take over my whole screen, I obviously use the proper html tag syntax for resizing but its clumsy and certainly not intuitive for less technical users.
I'm going to keep my eye on it, it looks like it has potential to me.
while exploring Github I found the software (SiYuan)
Then I searched Google with key words "siyuan joplin"
and the first search result leads me to this discussion
The Github page of this software Siyuan says that it is an open source.
source (Website Link): GitHub - siyuan-note/siyuan: A privacy-first, self-hosted, fully open source personal knowledge management software, written in typescript and golang.
(I love joplin and badly expecting the inter link feature in joplin so i am exploring all the opensource Note taking software which have the option to interlink in that process i ended up here
and
I am new to opensource, joplin, github, I am bit confused whether that software SiYuan is open source or Proprietary software , please enlighten me)
What do you mean by this, pls?
but this in trilium cost "$2.50/month gets you a hosted Trilium Notes instance you can connect to from anywhere" https://trilium.cc/
I love very much the rich text editor available in gitlab wiki pages since gitlab 14.0. Feels like the perfect mix between writing markdown and not. And seems to work fine in mobile.
snap, now how am i supposed to triple hashtag for emphasis in rich ed !
jk , looks pretty seamless in all seriousness
