- Cloud sharing - Joplin Cloud Sharing
- Readonly credentials
- Sharing as Public URL where no credentials is required
Thanks
Thanks
Should be available from next release
When is the next release date?
It's all here:
Is all the 3 will be available in the next release ???
2 yes, if I understand correctly what your mean. 1 and 3 probably not
@laurent why the public sharing URL is difficult for cloud web app ? any specific reason? we can control the number of simulataneous connection via a setting if performance is going to be an issue
