My first data call fails
this is straight from the example posted for data plugin. it does not work using curl. what am i missing?
C:\Users\murth>curl  http://localhost:41184/notes?token=f7dc220a450f7af904e4e4c02336f4310a287fa392eb3652f5cd45768fe86ae50976411d5994760a7fe9a1c0c94a9843d58b03d12f8e4c21df712934055832bf --data '{ "title": "My note", "body": "Some note in **Markdown**"}'
{"error":"Internal Server Error: Unexpected token ' in JSON at position 0: \n\nSyntaxError: Unexpected token ' in JSON at position 0\n    at JSON.parse (<anonymous>)\n    at Object.<anonymous> (C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\routes\\notes.js:348:38)\n    at Generator.next (<anonymous>)\n    at C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\routes\\notes.js:8:71\n    at new Promise (<anonymous>)\n    at __awaiter (C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\routes\\notes.js:4:12)\n    at Object.default_1 [as fn] (C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\routes\\notes.js:324:12)\n    at Api.<anonymous> (C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\Api.js:155:41)\n    at Generator.next (<anonymous>)\n    at C:\\Users\\murth\\AppData\\Local\\Programs\\Joplin\\resources\\app.asar\\node_modules\\@joplin\\lib\\services\\rest\\Api.js:8:71"}curl: (3) URL using bad/illegal format or missing URL
curl: (3) unmatched close brace/bracket in URL position 26:
Some note in **Markdown**}'
Looks like an issue between the windows version of curl and curl on other systems. A quick search online says that you might need to wrap the url with double quotes (").
I think you might have to do the same for the JSON, but I'm not sure how easy that will be.
FYI, I copied the curl command above and it runs fine on Ubuntu, so this is certainly due to the windows curl implementation.
Curl is an alias to Invoke-WebRequest (a Powershell function), if you want curl as it is on other platforms, you need to specifically call it as curl.exe
Or you can run it from within WSL, which might be better if you plan to run commands you've found on the net more often.
