Math mode usage
I don't understand how math mode is supposed to be used. Maybe you can tell me how you use it.
When an operation is made (Ex: 1200.9) it shows the result in the editor tab but it doesn't on the preview tab. In the preview tab it still shows the operation (1200.9) without the result but what's the point then? Does it not create unnecessary text in the preview tab when performing an operation?
Example in the screenshot. I've never used a note app before and i'm confused.
The plugin is for doing math inside the editor. This works nicely for my workflow because I don't use the preview tab.
