Less than symbol (<) in a style element?
Joplin 3.6.14 (prod, win32)
Device: win32, Intel(R) Core(TM) i7-4700HQ CPU @ 2.40GHz
Client ID: 9470a5e15005470290a4d0c3e23c1f52
Profile Version: 49
Alternative instance ID: -
Sync target: OneDrive
Editor: Markdown
Revision: 7e2765a
Backup: 1.5.1
Freehand Drawing: 4.3.0
OneDrive
Is there any way to escape a less than symbol (<) in a style tag?
When using a less than symbol (<) in HTML it is converted to &lt;. This means CSS that relies on this symbol breaks.
For example the following CSS changes colour using the attr() CSS function.
<style>
    [data-color] {
        color: attr(data-color type(<color>));
</style>
<span data-color="blue">foo</span>
However, it does not work in the viewer. Inspecting the element shows that the color property has been parsed as attr(data-color type(&lt;color>));, which is invalid.
The CSS works as intended when in the stylesheet.
