Joplin with mailfence
Hi, I wanted to use Joplin as a keep replacement, and since my subscription to mailfence gives me storage with webdav I wanted to use that.
When I put.in the info and check it it says that all is good but when I press sync it says
Lasterror:error:mkcol.sync/
unknown error 2(404)
Does anybody have a way to make it work?
Hi, i know this is an old post, but i'm actually wanting the same thing! Can't make it work though. I already tried adding a empty directory "joplin" (with and w/o capital J) and also tried adding a file in there. Nothing works. I'm getting the same error.
Did you ever manage to make it work?
Check this post with the solution, maybe: Error: PROPFIND locks/: Unknown error 2 (404)
I got it to work! I'd needs the specific /private/ directory after the mailfence webdav URL for it to work. It looks like the public directory is accessible without the correct credentials. Only the private subdir needs the credentials.
Great! Worked with me too. Thanks for the tip!
