joplin sync issue,
i saw duplicated file on android joplin, hence deleted one of the duplicated file, , then a few moment later i realized both of the file is gone.
this is a big problem for sync… headache.
joplin sync issue,
Please try to make the title of your posts shorter (I’ve shortened this one). Just put a summary of the content of your post, not the entire post in your title.
Deleting files from the file system is usually not a good idea unless you know what you are doing…
