- The version you are using. LATEST VERSION is not a version number!
Joplin for Desktop
Joplin 1.2.6 (prod, darwin)
Sync Version: 2
Profile Version: 34
Revision: f5f117c (master)
- The operating system you are using.
MacOs Mojave 10.14.6
The Issue
Joplin gets stuck when exiting the application and requires a force close to completely stop the app.
When reopening the app, the following dialog box error message is shown. Joplin continues to function normally otherwise.
This Joplin app currently has auto-update enabled.
Uncaught Exception:
RangeError [ERR_OUT_OF_RANGE]: The value of "err" is out of range. It must be a negative integer. Received 536870212
at Object.getSystemErrorName (util.js:220:11)
at exceptionWithHostPort (internal/errors.js:495:21)
at internalConnect (net.js:907:16)
at defaultTriggerAsyncIdScope (internal/async_hooks.js:301:12)
at GetAddrInfoReqWrap.emitLookup [as callback] (net.js:1050:9)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10)
Hope this helps!
