Issue with the context menu when I right-click the mouse from Note list or over a text on MD editor
Joplin 3.3.2 (prod, linux)
Client ID: 747a5551c4594f0c9f6cf085b4c4a4b2
Keychain Supported: No
Revision: 200d3c8
Backup: 1.4.2
Chat GPT Search: 1.0.0
Combine notes: 1.2.2
Conflict Resolution: 1.2.3
Copy Anchor Link: 1.1.0
Copy Universal Web Link: 0.1.2
Create and go to tags and @notebooks: 1.3.7
Freehand Drawing: 2.15.0
Github Alerts: 1.0.5
Hotfolder: 1.2.1
Inline TODO: 1.7.1
Joplin Batch: 0.2.2
Joplin DDDot: 0.4.2
Joplin Disk Usage: 1.3.1
joplin-excalidraw: 1.3.0
KanMug: 1.2.5
Markdown Table: Sortable: 1.2.2
Math Mode: 0.7.1
MultiMarkdown Table Tools: 1.2.1
Note list and sidebar toggle buttons: 1.0.3
Note overview: 1.7.1
Note Tabs: 1.4.0
OCR: 0.3.2
Paste Special: 1.1.2
PlantUML2: 1.11.0
Quick Links: 1.3.2
RevNav: 1.0.0
Rich Markdown: 0.16.0
Sepremento's Awesome Graph: 1.1.1
Slash Commands: Datetime & More: 1.4.0
Time Slip: 1.0.2
Toggle Editor Menu & Keyboard Shortcut: 1.0.1
ToWebSearchEngine: 1.0.2
OneDrive
When I right-click on a note in the note list section, the context menu appears but disappears before I can choose an option. The only way to use the context menu is to quickly move the mouse to another part of the screen; otherwise, the menu closes before I can select the desired option. A similar behavior occurs when I right-click on a text in the Markdown editor, where sometimes I inadvertently select any context menu option before disappearing and selecting the desire option.
This may not end up being the culprit, but I would strongly suggest testing with plugins disabled. You've got so many installed that I'd be very surprised if there weren't any conflicts between them :sweat_smile:.
Right, I have disabled the last plugin I installed Joplin Plugins - Copy Universal Web Link, that added some options to this context menu, and this fixed the problem. Please, @benlau could you check this issues relate to your plugin producing this behavior?
