I'm playing around with the built in OCR feature and the search function seems to work great. Now is there a way I can copy and paste the text that I find within images and pdfs?
Thanks
Hi
I use this manual process:
- For image, I have installed OCR plugin, using it you can copy & paste text from image after run OCR process.
- For PDF, I can go to the viewer sidebar and copy & paste text as well.
I do not know if there is another simpler way, but this is working well for me.
Ok yea I was curious if this would work with the built in OCR function, rather than a plugin. I'll give the plugin a shot.
