I am using linux and I have installed the desktop and terminal client.
They both create separate directories in the .config directory joplin and joplin desktop.
I have to setup synchronization for both of them separately, they can't use each other's databases or resources.
Is this something wrong with how I've set it up or is it by design?
Is there any way to have both desktop and terminal applications share the same sync settings?
No nothing wrong, this is by design. Each Client has it's own database.
