Integrate with system
Each time I start Joplin , Iget
'Would you like to integrate …with your system?.."
I DO NOT NEED THAT
How can I get rid of this notification ?
Pretty sure that is a system thing, and not because of Joplin, so you need to look into the settings of your system.
(I assume this is a Ubuntu flavor since I get the same)
I does not have ubuntu , but debian UN STABLE (SIDUCTION)
If it is system setting : then ALL APPIMAGES must have the same behaviour, but it is not the case.
Developper just add what they want .
Indeed this is something that can be disabled during the build process, but it is a feature that some people use. If you select yes the pop-up won’t reappear until you update Joplin.
Alternatively if you update Joplin using the update and install script, this pop-up shouldn’t appear at all, of it does that’s a bug and please report it.
Just set environment variable APPIMAGE_SILENT_INSTALL:
export APPIMAGE_SILENT_INSTALL=false
I just use a copy of application image , no built of other things , so …
less use of Joplin
If you set the environment variable APPIMAGE_SILENT_INSTALL in your login profile, you’ll never be bothered again.
Where to do that , I download appimage and copy it to directory and then run it
