Insert pictures or screnshots into a note
Joplin 3.7.18 (prod, win32)
Hello all, I consider using Joplin to replace OneNote but trying it I realize that I cannot insert pictures or screenshot like I do very easily with OneNote. I red about the webclipper but this is too complex for me. Someone can help me with this ? thanks
Adding pictures is quite simple.
I use two different methods.
The first is to copy the picture to the clipboard and paste it into the markdown editor.
The other is to drag a picture from file explorer into the markdown editor.
I'm pretty sure I just tested that you can also paste into the rich text editor too.
Thank You LeoW
