I'm wondering, is there any way to include image files using the command line interface of joplin?
You use the attach command.
e.g. attach $n /home/user/pictures/unicorncatpicture.png
Great, thank you! Could it also work with images from the clipboard?
I don't think it does but if someone knows if that can be implemented then I'm sure PRs would be accepted for it.
