Creating a code block with Html syntax will makes Joplin slow beyond practical use.
Joplin v. 1.0.216
Win 10 OS
Joplin v. 1.0.216
Win 10 OS
How much html?
I have just pasted the entire Wikipedia home page into an HTML code block in Joplin. It did occasionally judder a bit as I scrolled the viewer pane whilst the code was being highlighted on the fly. I am assuming it was the highlighter as when I changed the code block to
```plaintext
the judder stopped.
Joplin 1.0.216 | Win10 Pro x64
the occurrence is more isolated then i thought.
the html code blocks are fine when using joplin normally.
however when debugging mode has activated, as described here: https://joplinapp.org/debugging/
you will notice that html code blocks will make joplin slow.
I suppose that performance degradation is not that unexpected if Joplin is doing a lot more work running the dev tools and logging everything.
