Hi
Quick question, how to find the following occurrences following a search in a note (markdown editor)?
After using CTRL + F and typing my search, I usually use CTRL + G to search for the following and CTRL + SHIFT + G to go back under other applications, but this doesn't work with Joplin
In the markdown editor, it should be possible to navigate between search results with enter and shift-enter.
(CTRL-G and CTRL-SHIFT-G should work in the beta markdown editor (can be enabled in settings > Opt-in to the editor beta). )
Thank you very much, it was very simple
I'll avoid the beta editor for now...
