Hi
Is there a plugin or secret feature that allows to downscale or optimize (e.g. lower quality) for already attached images to reduce their size?
The goal is to optimize space used by Joplin resources and particularly images.
Thanks
Hi
Thanks
You can't change the image quality/file size (in base Joplin at least) but you can change how it is displayed by using an HTML tag rather than the markdown one:
e.g.
<img src=":/4d3038829ac35a048e2c67ea143c365d" width="400">
rather than
Otherwise you could always just run a batch image converter over your resources folder, so long as the names remain the same then it should work (just back it up first, it isn't something I've tried).
Hey @Daeraxa . Thanks for your reply, but I don't mean just "showing" a different size. My goal is to optimize space used by Joplin resources and images take the largest space. Do you know if after I will convert images in resources/ as per your suggestion, will it be properly synchronized to other devices? In other words, does Joplin track resource file changes?
Thats a good point. It definitely tracks changes if you open the resource from the note but I don't know if it will create a new sync if you just change the file sizes en masse.
Depending on how essential it is, you could manually replace the resources directory on your sync target with your new, smaller one from your profile directory then it should work as they should be identical- with a massive caveat that you do so at your own risk after backing up as much as you can.
Hello there, here's definitely not a secret but recent plugin that lets you replace your resources including images.
It works like that:
The advantages of this method:
@graphit0 Thanks! Looks very interesting and kind of what I need!
