- Link to the project idea: gsoc/ideas.md at master · joplin/gsoc · GitHub
- GitHub profile: lakshsarda137 · GitHub
- Forum introduction post: Welcome to GSoC 2026 with Joplin! - #86 by lakshsarda137
- Relevant development experience: I’ve built a Chrome extension that takes a sequence of web pages as input and, based on the page content, queries an LLM to determine whether the pages contain relevant information for the user's question.
- Introduction
- Background/Studies: I’m Laksh, an undergraduate student majoring in Computer Science and Mathematics at Rice University in the United States. I’ve taken courses on DSA, Data Science & Machine Learning, and Linear Algebra, among other courses.
- Programming experience: I’ve been building projects alone or with my friends for the past 3-4 years, and have learnt Python, TypeScript, JavaScript, and multiple frameworks on AWS/GCP/Azure along the way.
- Experience with open source: I’ve only forked open source repositories and customized them to meet my needs in the past. However, I have now started contributing to open source repositories.
- Project Summary
What problem it solves: As users start using Joplin for longer periods of time, they may struggle to find notes they took on a relevant topic a while ago.
What will be implemented: A Joplin plugin that lets users chat with their entire note collection through an LLM-powered conversational interface. The plugin will use Retrieval-Augmented Generation (RAG) to generate LLM responses in the user's actual notes, ensuring answers are factual and traceable.
Expected outcome: Users can open a panel in Joplin, ask natural language questions about their notes, and receive accurate answers with clear references to the source notes. Follow-up questions refine the conversation. There should be no hallucination; every claim is backed by retrieved note content.
- Technical Architecture
Architecture:
The plugin follows a standard RAG pipeline with three core components:
User Query → Embedding + Retrieval → Context Assembly → LLM Generation → Response with Citations
Indexing Pipeline: On the first run (and incrementally thereafter), the plugin reads all notes via joplin.data API, chunks them, generates embeddings, and stores them in a local vector database.
Retrieval Engine: When the user asks a question, the query is embedded, and the top-k most relevant note chunks are retrieved via similarity search.
Generation with Citations: Retrieved chunks are assembled into a prompt with the user's question, sent to the LLM, and the response includes references to source note IDs/titles that the user can click to navigate to.
Components involved + Libraries/Technologies I plan to use:
| Component | Technology | Rationale |
| Vector Store | Vectra | Pure TypeScript, no native dependencies, runs in plugin sandbox, stores index locally alongside Joplin data |
| Embeddings | OpenAI text-embedding-3-small or local alternative (e.g. Transformers.js) | User-configurable; OpenAI for quality, local for privacy |
| LLM | OpenAI / Anthropic / Ollama (user-configurable) | Flexibility: users who want privacy can use local Ollama models |
| Chunking | Recursive character text splitter | Splits notes into ~500-token chunks with overlap, preserving note metadata (ID, title) per chunk |
| UI | Joplin Panel API | Chat interface rendered as a sidebar panel using HTML/CSS/JS |
Changes to the Joplin Codebase:
This project is implemented as a plugin, so no changes to Joplin core are needed. The plugin uses:
joplin.data.get(['notes'], { fields: ['id', 'title', 'body', 'updated_time', 'parent_id'] })for note access -
joplin.data.get(['folders'])andjoplin.data.get(['tags'])for context -
joplin.workspace.onNoteChange()for incremental index updates -
joplin.views.panels.create()for the chat UI -
joplin.settings.registerSection()/registerSettings()for API key configuration and model selection -
joplin.commands.register()for keyboard shortcut to open chat
For the technical architecture, I also plan to use a couple of strategies to avoid a couple of problems I foresee:
Incremental Indexing Strategy
Rather than re-indexing all notes on every launch:
Store
updated_timeper indexed note -
On startup, query notes with
updated_time > last_index_time -
Re-embed only changed/new notes; remove deleted notes from the index
This keeps the plugin responsive even with thousands of notes
Handling Hallucination
Strict grounding prompt: The system prompt instructs the LLM to only answer based on the provided context and to say "I don't have information about that in your notes" when the context is insufficient
Citation enforcement: Each response chunk is tagged with source note IDs; the UI renders these as clickable links
Confidence thresholding: If retrieved chunks have low similarity scores, warn the user that results may be incomplete
Potential Challenges:
Large note collections: Embedding thousands of notes takes time. Mitigated by incremental indexing and a progress indicator during initial setup.
Plugin sandbox constraints: Plugins run in a sandboxed environment. Vectra's pure-JS approach avoids native dependency issues. For local models, Ollama runs as a separate process the plugin communicates with via HTTP.
Privacy concerns: Some users won't want notes sent to external APIs. The plugin will support fully local pipelines (Ollama + local embeddings) as an option.
Context window limits: Long notes need chunking. The chunking strategy preserves semantic coherence and overlaps chunks to avoid losing context at boundaries.
4. Implementation Plan
Week 1–2
Implement note ingestion pipeline: fetch all notes via data API, chunk them with metadata
Implement embedding generation (OpenAI API integration)
Set up Vectra vector store, store and persist embeddings locally
Week 3–4
Implement query pipeline: embed user query, retrieve top-k chunks, assemble context
Implement LLM integration for answer generation with citation extraction (only external providers for now)
Basic CLI/console-based testing of the full RAG pipeline
Week 5–6
Build the chat panel UI using Joplin's Panel API
Implement conversation history (multi-turn chat)
Add clickable note references that navigate to source notes
Midterm Evaluation
- Deliverable: Working plugin with basic chat functionality, note indexing, and source citations
Week 7–8
Implement incremental indexing (only re-embed changed notes)
Add
onNoteChangelistener for real-time index updates -
Implement settings panel: API key config, model selection, index management
Week 9–10
Add support for local/Ollama models as an alternative to cloud APIs
Add support for local embeddings (Transformers.js or Ollama embeddings)
Performance optimization: batch embedding, caching, lazy loading
Week 11–12
Comprehensive testing: unit tests for chunking/retrieval, integration tests for full pipeline
Edge case handling: empty notes, very long notes, notes with images/resources
Documentation: user guide, developer setup guide, architecture docs
Final Week
Final polish, bug fixes from mentor feedback
Submit final evaluation
5. Deliverables
Joplin plugin (publishable to the Joplin plugin repository) with:
Natural language chat interface for querying notes
RAG pipeline with local vector storage
Clickable source citations linking back to original notes
Support for multiple LLM providers (OpenAI, Anthropic, Ollama)
Incremental indexing for efficient updates
Configurable settings (model, API keys, privacy mode)
Tests: Unit tests for chunking, embedding, retrieval, and citation extraction; integration tests for the full query pipeline
Documentation: User-facing guide (how to install, configure, and use) and developer documentation (architecture, how to extend)
6. Availability
Weekly availability: ~40 hours per week during GSoC
Time zone: IST (Indian Standard Time)
Other commitments: I will be on summer break from university during the GSoC period, so I can dedicate substantial time to the project. No other major commitments.
