Fonte awesome installed but Joplin not rendering them
Hi, can anyone tell me why this is happening, please?
The text in Xed & Joplin were both pasted from the same clipboard copy
Joplin 2.8.8 (prod, linux)
Client ID: dd8edcb750f441f7abbfbdcd5336bc4e
Profile Version: 41
Keychain Supported: No
Revision: c2a6a13
From the look of the text in the editor pane you haven't told Joplin to deviate from the default body font. I guess you need an inline font style similar to:
set $ws1 "1: <font style="font-family:fontawesome;">x</font>"
where x is the character you want to display.
I do not know if the fontawesome font is called "fontawesome" for the purposes of styling as I do not use it, but hopefully you get my gist...
Edit:
Just loaded a FontAwesome font variant to test this.
set_font
Thanks!
But, unfortunately that doesn't work in a code block :frowning:
