macOS
Joplin 3.6.14 (prod, darwin)
Device: darwin, Apple M3 Pro
Client ID: fb5f82bf87a845e2b62a76afeb34bee3
Profile Version: 49
Alternative instance ID: -
Sync target: Joplin Cloud
Editor: Markdown
Revision: 7e2765a
Backup: 1.5.1
Freehand Drawing: 4.3.0
Migrated Notes from Evernote are not OCR Searchable?
I seem to not be able to search INSIDE of Images or PDFs that contain Images, even though I can access and open their OCR Text through "View OCR Text" command. But that OCR Text doesn't seem to be searchable. What can I do to include the OCR Text in searches?
I actually think - The problem is that the OCR Data comes from Evernote, it's viewable in Joplin, but I dont seem to be able to include those OCR data in Search. But I also can't find any switch to include that OCR data in my Search. The Files I am referring to are all Text Based images / PDFs - not handwritten.. Is there a Way to make JOPLIN re-OCR everything somehow ?
I can suggest two ways worth exploring:
Disable and re-enable Joplin's own OCR feature in settings/general. The new parsing might take a while (hours).
Export all your notes as JEX and reimport them (eg in a new profile). Afaiu with this method, from the pov of Joplin, it will be like regular notes, Joplin would not have a way to know they ever were Evernotes at some point earlier.
You could quickly test method 2 on a small subset of your notes to get a fast answer.
Thank you for your Answer. Very much appreciated!
- On the topic of re-OCR the Files, would I see a Process using a lot of CPU? Or will that happen in the Joplin-Cloud ( I guess not )
- This would mean I would have to export a lot of notes, but I see your point. Will try
