I manage my notes like book's toc:
But Joplin will lose this structure when I change to another platform.
Is there any way to sync "sort order" between all devices?
I would also much appreciate this. I am currently adding prefixes to my notes so that the alphabetic sort order equals my custom order. If the sort order was synced, this would save me a ton of time.
I think this is a bug.
When you change the order of a task, the only order data(order field) will be changed in the db(sqlite)
Updating the time of task(updated_time or user_updated_time) is needed to sync data with other device. But in this situation the order was just changed so sync couldn't be happened.
I'll give you a tip for this problem.
@ravenxrz are you aware of the View > Sort notes by menu? Are you using Updated Date, Created Date, Title, or Custom Order in that setting?
This is the solution, just tested this on Windows, OSX, and Debian.
