Feature request: Easier switching between note and to-do type
Presently I have to do two operations for that: switch the note to to-do (and, on Windows desktop version, sometimes I have to search for the note in the Notes List, even if I have the note text open in the editor); then set the alarm.
I propose merging "Switch between note and to-do type" and "Set alarm" operations to the single "set alarm". I.e. when I edit the note, I should be able to simply click the (grayed) bell toolbar icon (on Windows version) or select "Set Alarm" (on Android version). That will automatically convert the note to to-do and invoke the Set Alarm popup.
In the Set Alarm popup we'll need one more button after "Clear alarm": "Switch from to-do into note".
+1, would also love to see a keyboard shortcut for switching between note types and/or setting an alarm
Old topic, I know, but my request is the same as joshb's: would love a keyboard shortcut (or a menu item that I could bind to a keyboard shortcut) for switching between note and to-do type.
This has also been requested here:
Thanks for considering.
The closest keyboard workaround for switching note types is opening Command Palette with Ctrl+Shift+P, then selecting the toggleNoteType command.
I'm not sure why the command doesn't show up in the Keyboard Shortcuts menu.
