FATAL ERROR: Cannot read properties of undefined (reading 'key')
Can't retrieve
Joplin Cloud
Not sure what I was doing at the time, but CRASH. Tried opening in safe mode and it still will not open. Help!
Error
Joplin encountered a fatal error and could not continue.
To report the error, please copy the *entire content* of this page and post it on Joplin forum or GitHub.
If the error persists you may try to restart in safe mode, which will temporarily disable all plugins.
Message
Version info
Joplin for Desktop
Copyright © 2016-2026 Laurent Cozic
Joplin 3.5.12 (prod, linux)
Device: linux, AMD Ryzen 7 8845HS w/ Radeon 780M Graphics
Client ID: 9959465eea794e60b1b95760c308ca91
Profile Version: 49
Keychain Supported: No
Alternative instance ID: -
Revision: 449555c
Backup: 1.5.1
Combine notes: 1.2.3
Conflict Resolution: 1.2.3
Extra Markdown editor settings: 1.11.0
Favorites: 1.3.2
Freehand Drawing: 4.2.0
History Panel: 1.0.4
Hotfolder: 1.2.3
Import local CSS: 1.1.0
Inline tags: 1.3.0
Inline TODO: 2.0.5
Jarvis: 0.12.0
Joplin DDDot: 0.4.4
Kminder Mindmap: 0.8.7
Markmap: 1.9.1
Note list (Preview): 1.1.0
Note list and sidebar toggle buttons: 1.0.3
Note Rename: 1.0.0
Note Tabs: 1.4.0
Plugins
        "id": "com.whatever.quick-links",
        "name": "Quick Links",
        "enabled": true,
        "version": "1.3.2"
        "id": "io.github.jackgruber.backup",
        "name": "Backup",
        "enabled": true,
        "version": "1.5.1"
        "id": "com.whatever.inline-tags",
        "name": "Inline tags",
        "enabled": true,
        "version": "1.3.0"
        "id": "joplin.plugin.templates",
        "name": "Templates",
        "enabled": true,
        "version": "3.0.0"
        "id": "joplin.plugin.space-indenter",
        "name": "Space Indenter",
        "enabled": true,
        "version": "0.2.6"
        "id": "joplin.plugin.note.tabs",
        "name": "Note Tabs",
        "enabled": true,
        "version": "1.4.0"
        "id": "io.github.jackgruber.combine-notes",
        "name": "Combine notes",
        "enabled": true,
        "version": "1.2.3"
        "id": "plugin.calebjohn.todo",
        "name": "Inline TODO",
        "enabled": true,
        "version": "2.0.5"
        "id": "joplin.plugin.benji.favorites",
        "name": "Favorites",
        "enabled": true,
        "version": "1.3.2"
        "id": "com.cuibonobo.NoteRename",
        "name": "Note Rename",
        "enabled": true,
        "version": "1.0.0"
        "id": "joplin-plugin-conflict-resolution",
        "name": "Conflict Resolution",
        "enabled": true,
        "version": "1.2.3"
        "id": "io.github.jackgruber.notelistpreview",
        "name": "Note list (Preview)",
        "enabled": true,
        "version": "1.1.0"
        "id": "de.fomin.markmap",
        "name": "Markmap",
        "enabled": false,
        "version": "1.9.1"
        "id": "org.joplinapp.plugins.whitespacer",
        "name": "Whitespacer",
        "enabled": false,
        "version": "1.0.2"
        "id": "io.github.jackgruber.hotfolder",
        "name": "Hotfolder",
        "enabled": true,
        "version": "1.2.3"
        "id": "io.github.jackgruber.copytags",
        "name": "Tagging",
        "enabled": true,
        "version": "1.0.3"
        "id": "outline",
        "name": "Outline",
        "enabled": false,
        "version": "1.5.15"
        "id": "org.joplinapp.plugins.YesYouKan",
        "name": "YesYouKan",
        "enabled": true,
        "version": "1.1.3"
        "id": "calandra.kminder.joplin",
        "name": "Kminder Mindmap",
        "enabled": true,
        "version": "0.8.7"
        "id": "joplin.plugin.benji.persistentLayout",
        "name": "Persistent Editor Layout",
        "enabled": true,
        "version": "2.2.0"
        "id": "io.github.personalizedrefrigerator.diff-view",
        "name": "Diff view",
        "enabled": true,
        "version": "0.3.1"
        "id": "joplin.plugin.alondmnt.sticky-note",
        "name": "Resume Note",
        "enabled": true,
        "version": "0.4.2"
        "id": "io.github.personalizedrefrigerator.import-local-css",
        "name": "Import local CSS",
        "enabled": true,
        "version": "1.1.0"
        "id": "joplin.plugin.alondmnt.history-panel",
        "name": "History Panel",
        "enabled": true,
        "version": "1.0.4"
        "id": "io.github.personalizedrefrigerator.js-draw",
        "name": "Freehand Drawing",
        "enabled": true,
        "version": "4.2.0"
        "id": "joplin.plugin.alondmnt.jarvis",
        "name": "Jarvis",
        "enabled": false,
        "version": "0.12.0"
        "id": "org.joplinapp.plugins.ToggleSidebars",
        "name": "Note list and sidebar toggle buttons",
        "enabled": true,
        "version": "1.0.3"
        "id": "com.joshthor.export",
        "name": "Save Note as MD",
        "enabled": true,
        "version": "1.0.2"
        "id": "io.github.personalizedrefrigerator.codemirror6-settings",
        "name": "Extra Markdown editor settings",
        "enabled": true,
        "version": "1.11.0"
        "id": "net.rmusin.joplin-table-formatter",
        "name": "Table Formatter Plugin",
        "enabled": true,
        "version": "1.2.1"
        "id": "joplin-plugin-dddot",
        "name": "Joplin DDDot",
        "enabled": true,
        "version": "0.4.4"
Stack trace
TypeError: Cannot read properties of undefined (reading 'key')
    at calculateChildrenSizes (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/gui/ResizableLayout/utils/useLayoutItemSizes.ts:87:39)
    at calculateChildrenSizes (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/gui/ResizableLayout/utils/useLayoutItemSizes.ts:115:25)
    at file:///tmp/.mount_joplinA6BbCR/resources/app.asar/gui/ResizableLayout/utils/useLayoutItemSizes.ts:151:11
    at mountMemo (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3910:9746)
    at Object.useMemo (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3910:15081)
    at useMemo (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3832:1158)
    at useLayoutItemSizes (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/gui/ResizableLayout/utils/useLayoutItemSizes.ts:141:9)
    at ResizableLayout (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/gui/ResizableLayout/ResizableLayout.tsx:162:16)
    at renderWithHooks (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3910:419)
    at mountIndeterminateComponent (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3926:11328)
Component stack
    at ResizableLayout (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:4645:18336)
    at div
    at MainScreenComponent (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:5652:491)
    at ConnectFunction (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3973:23763)
    at div
    at NavigatorComponent (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:5867:2085)
    at PopupNotificationProvider (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:4830:1202)
    at Py.ThemeProvider (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:4450:264)
    at ae (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:4435:2912)
    at RootComponent (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:6427:62)
    at ErrorBoundary (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:5397:24683)
    at Provider (file:///tmp/.mount_joplinA6BbCR/resources/app.asar/main-html.bundle.js:3977:1461)
Log file
log.txt (65.1 KB)
Looks like the same issue as here: Error loading app after update to 3.4.12 - #12 by shauneverson
Have a read through the posts for a suggested solution (editing settings.json)
Thanks. I searched for it, but that one did not pop up for me. Regardless… BAM! I am working again.
My layout is insanity again, but … it’s working. :slight_smile:
Thanks.
@laurent There is a bug … somewhere. :slight_smile:
