Joplin 3.3.12 (prod, win32)
Device: win32, 12th Gen Intel(R) Core(TM) i7-12800HX
Client ID: 4c5001f692bb436f87e2f9f83e660b48
Keychain Supported: No
Alternative instance ID: -
Revision: 4d790b6
Auto show active note in sidebar: 1.0.1
Backup: 1.4.3
Combine notes: 1.2.2
Convert Text To New Note: 1.5.1
Hotfolder: 1.2.2
Note list and sidebar toggle buttons: 1.0.3
Outline: 1.5.14
Quick Links: 1.3.2
I use OneNote with external links to JoplinPortable. In use: I open the portable Joplin, then in OneNote, I click an external link to open the linked note in Joplin. This worked, at least a few months ago. Now the link opens a second instance of Joplin. I can't tell where this comes from. Joplin is not listed as installed. The help screen of this instance Shows:
Client ID: 95137470fe7d41dcb189b5555a1fd49a
Revision: 4d790b6
Backup: 1.4.3
Freehand Drawing: 3.0.1
This instance has only starter notes
This differs from the Help screen of the portable version (above).
I tried using older versions of Joplin Portable. Findings: 3.3.2 works as I expect. The Portable note opens. Using 3.3.3 shows the 2nd instance.
I tried a few other things: I erased the AppData\Joplin Folder. Then trying the new version, no change. I Deleted the folder again, and tried 3.3.2, where the links worked. The Folder after 3.3.12 was used had several more folders and files, than the trial using 3.3.2.
Can this be fixed? I'd like to keep current with the App, but I need the links to work. I'm not sure where the starter notes in the new instance would be kept as I always delete them from my portable data. Is there another folder besides the AppData\Joplin folder that I need to remove.
I do not synchronize.
Thanks
Mike
