Apologies if this is the wrong section.
When I export PDF with a black background, why is the block of code in it white instead of black in preview mode.
But it changed the style when I exported it:
Because I was limited to uploading only one image,the color of the code block is the same as the color of the edge of the image above.
I tried to change the userstyle.css:
code {
background-color: #222222;
white-space: pre-wrap;
It only changed the code's color but not the block.
