How to Change Code Block Background Color?
Joplin 3.3.13 (prod, win32)
Device: win32, 13th Gen Intel(R) Core(TM) i7-13800H
Client ID: 756c6fdd606944568e94552736699771
Alternative instance ID: alt1
Revision: 144ed59
Backup: 1.4.3
Copy Code Blocks: 2.0.0
Freehand Drawing: 3.0.1
Insert Date: 1.0.1
Note list and sidebar toggle buttons: 1.0.3
Nextcloud
I am able to change the background color of text lines in code blocks by adding the style definition to userstyle.css:
code,.inline-code {
background: #d6d3d1;
But how do I make the color of the code block itself darker? In the attached screenshot, I would like the darker grey behind the entire text stanza, not just behind the text itself.
Not 100% sure if this will work but you can give it a try.
That doesn’t seem to be working for me. :pensive_face:
I appreciate the reply, though!! :grinning_face:
This works for me:
pre.hljs {
I’m seeing that this is similar to LeoW’s link that you said didn’t work for you, though. To get this I opened Joplin’s Help menu, then selected “Toggle development tools”. That opens a new pane. In the very top left of that new pane is this icon:
image (you can also just press Ctrl+Shift+C once the dev tools are open)
When clicked, you can move your mouse over your code block until the entire thing is highlighted - and once it is, the little popup will tell you what element and class it is, for targeting in your CSS:
That works!! Thank you!!!
On a side note, the element inspector is brilliant. Until now, Joplin has just been a note-taking tool for me; it never occurred to me that it’s actually just an apparently Chromium-based browser. This dialogue changed how I will interact with the software; thank you for that, too!
Please keep in mind this is a randomly generated class name, which means that it may change anytime with future Joplin update. If possible, it’s better to target elements with proper classes or using HTML tags.
Edit:
This particular class is OK. See below for explanation.
The hljs class stands for “HighlightJS”, the library Joplin uses for code syntax highlighting in the webview
